Old 25-08-10, 01:11 PM   #1
McFly
Default Converting Curvy S to a Naked?
As per title really, finding the S too much for my back and knees but can't bear to part with her as so nice and only 5500 miles on 2002.
Has anyone ever done this and can anyone list exactly what is needed to do the job? Don't want to hack existing parts incase I want to reverse the job and definitely don't want to sell and buy another bike. I believe you can swop bars to raise a pointy but a curvy?
Away for 3 days now so all replies will be gratefully received when I get back.
Old 25-08-10, 01:29 PM   #2
Grinch
Default Re: Converting Curvy S to a Naked?
Its a stress mate, easier to just swap the bike but here goes...
  1. Choke cable needs to be replace, can be re-routed but the N is longer. Carbs off job.
  2. Throttle cables need to also be swapped, carbs off again.
  3. Clutch cable is also longer, so that needs to be swapped.
  4. Longer brake line cable will need to be obtained and connected to the splitter, or replace whole thing with 2 lines.
  5. Your also need to replace the brake master cylinder to fit to the high bars, this means a whole brake service is needed.
  6. Front loom is different so that will need to be sourced.
  7. Clocks are also different, your have a job finding N clocks.
  8. Top yoke is different as is the position of the ignition located in it.
  9. Panels need to be remove and subframe replaced.
  10. Frame mounts behind the rad in the main frame will also need to be removed, cutting is required.
  11. Rider foot-peg mounts are lower if I remember correctly, the 'triangles' are different sizes for N and S, this is optional really.
Some of this stuff can be avoided, like I have my existing yoke drilled and risers fitted for my Renthal bars. If you keep the front panels/clocks/sub-frame you need to cut down the fairing screen else you won't get the clearance you need at full lock.
Think that is everything.
Old 25-08-10, 04:03 PM   #3
I agree with what Grinch has said needs doing to convert it to a naked, but why do you want to go to all the trouble of making it a naked.
Just change the top yoke as Dan suggests and fit higher bars. If you do this, then all you need to change are the throttle, choke & clutch cables. Plus of course longer brake lines.
Matt Yokes on the forum makes these comfort kits for the Sv and gives orger's 25% discount I think. See the comfort kits here
http://www.streetfighterstore.co.uk/sv_650_s/123
To lower the footpeg position buy some of these plates and use them upside down.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
A cheaper way would be to buy a N model top yoke and buy the bars seperately.
Curvy S model is harder to convert as there's less room in the fairing gap
Old 27-08-10, 05:20 PM   #4
McFly
Just back and read your replies, thanks very much. I can see that my idea of converting to a naked is too much hassle and the 'Comfort Kits' available may be the answer.
Has anyone here actually bought and fitted a kit to a Curvy? The kit includes the required brake line but with regards to throttle, choke and clutch cables the text suggests the original can be used, is that correct? Finally, the 're-profiling' of the screen to get full lock; any idea just how much hacking is required?
Thanks again.
Old 27-08-10, 05:47 PM   #5
Send Mattyokes a PM he'll answer your questions. If you click on the Community list at the top, it'll give you a Members list, look for Matt under M
Plus he'll tell you what the current discount code is for his shop
If you don't get an answer straight away to your PM then I think he had some family problems, so he's not online as much as he usually is
Converting Naked to faired? liamsimpson SV Talk, Tuning & Tweaking 34 25-01-19 10:23 AM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
Looking at converting a naked to a S DaveW_42 SV Talk, Tuning & Tweaking 4 06-11-08 09:04 PM
Converting 02 650s to Naked twoccs SV Talk, Tuning & Tweaking 15 10-08-08 11:00 AM
Taking off the fairing on a 2002 SVS and converting it to look like a naked SV tmillard SV Talk, Tuning & Tweaking 10 22-05-07 02:44 PM
