Old 04-09-10, 11:18 AM   #1
andycj
Default SV650S comfort kit fitted - clutch cable problem.
Hi all, I've just fitted a comfort kit supplied by Matt from Streetfighter Store, very nice it is too. I've done away with the fairing altogether and fitted a set of Renthall's. My problem is the clutch cable, it's very tight on full lock, the 90 degree metal sheath on the handle bar end seems to hamper it quite severly. I've tried 3 or 4 differing routes and taken it out of the guide just under the tank but, I cant get it to how I would like it. I've spoken to Matt who says they've done many curvy 99 model conversions without any problem and suggested I post this thread as a fair number of you have this conversion already. Can anyone out there tell me the optimum route for the clutch cable please
Thaks in advance Andy.
Old 04-09-10, 11:39 AM   #2
punyXpress
punyXpress's Avatar
Default Re: SV650s Comfort Kit
Can you straighten out the elbow enough to give clearance?
Fitting Renthals to my K2 naked & may have the same problem.
Now: Street Triple R
Old 04-09-10, 12:26 PM   #3
maff
When i put my coversion kit on i routed the clutch cable to come out of the frame by the coolant resevoir bottle, up the side of the bike, around the out side of the left fork leg, up over the yoke and hey presto... no probs
You might want to cable tie something around the clutch cable so it doesnt mark the stonking yoke
hth
Old 04-09-10, 03:30 PM   #4
A clutch cable for a naked is a bit longer.
Old 04-09-10, 08:16 PM   #5
madness
Default Re: SV650S comfort kit fitted - clutch cable problem.
I didn't like any of the many cable routes I tried. I ended up swapping it for a DL650 cable (£10 from Wemoto) which if anything is a tad long.
Old 04-09-10, 08:31 PM   #6
cb1000rsteve
I'm selling my bike in the classifieds on here with pics of the comfort kit. Have a look AT PICS AND SEE HOW I ROUTED MINE. i NEVER HAD PROBLEM. touched caps lock key and can't be bothered to edit
Old 04-09-10, 09:20 PM   #7
xXBADGERXx
I have a pointy but I unclipped the cable from inside the frame and routed it OUTSIDE of the fork leg , the 90 degree bend rested very close to the Yoke but it wasn`t tight . Since then I have fitted a naked one as a replacement due to the age and amount of action the old cable had seen , the original one should still be fine though .
Old 06-09-10, 01:32 PM   #8
andycj
Hi, thats the route I've gone with, it's not that it doesn't work, it's just that on full left lock (i think, have to check again) it's too tight for my liking.
I think I'll go with a replacement from a naked version, seems to be the way to go.
Thanks for taking the time.
Old 06-09-10, 01:37 PM   #9
andycj
Thanks to everyone for taking time out to try and help me out, cant fault ya.
Old 06-09-10, 02:29 PM   #10
MrMessy
I fitted a LSL conversion to my 1st curvy and had problems with the original cable being too tight and it eventually snapped at the metal sheeve at the handlebar end. Fitted a naked model cable and that was fine.
MrMessy is offline   Reply With Quote
Clutch Cable silent11 SV Talk, Tuning & Tweaking 4 29-09-09 02:44 PM
SV650S K2 Clutch actuator problem(?) ssurprize SV Talk, Tuning & Tweaking 7 19-07-09 07:04 PM
New Clutch Cable SV650s curvey SOLD svscratcha For Sale - SV's and SV related items 3 22-04-09 04:44 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Clutch cable 21QUEST For Sale - SV's and SV related items 1 03-04-06 12:03 AM
