Old 09-09-10, 10:38 AM   #1
nipperju
Default 2001 Ignition barrel and key
Finding it harder and harder to turn the key for the steering lock and starting. Has anyone got an ignition barrel and key for an SV650s to sell? Thanks
Old 09-09-10, 11:46 AM   #2
rictus01
rictus01's Avatar
Default Re: 2001 Ignition barrel and key
Actually I do have a spare, although in all honesty it was swapped out for the same reason, it works but you have to rock the key forwards before you can turn it, Oh and it has two keys.
only kept it as a replacement for the wires should some scrote cut them,if you want it, let me know.
Cheers Mark
Old 09-09-10, 12:06 PM   #3
tactcom7
Do what I did and remove your ignition entirely! Replace it with a toggle switch under your rear pillon seat works a treat.
Old 09-09-10, 01:53 PM   #4
Aidan
Search on the forum - when mine gets hard to turn I spray some WD40 into it to flush it, get the key turning and then add some oil to the lock (I use 3 in 1). Some will say not to do it as it wears the barrel, but hey - I can't remeber what they suggest using instead of oil.
Ignition barrel sticking gedcarney SV Talk, Tuning & Tweaking 8 15-02-09 10:09 AM
Ignition barrel borked after off? MiniMatt SV Talk, Tuning & Tweaking 1 26-10-07 11:37 AM
Ignition Barrel Help! krhall Bikes - Talk & Issues 7 19-02-07 11:13 PM
Ignition Barrel BILLY SV Talk, Tuning & Tweaking 12 24-08-06 09:02 PM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
