Old 23-09-10, 08:51 PM   #1
mulvanny1
Default New Bridgestone BT023, now poor handling.
lookin for some help hear. had to get new front tyre for mot. I went for a Bridgeston battlax-023 ST. the bike has tanked slapped a few times and feels like it has no grip. i ran it in about 130 miles. been out 3 times and its happend more than once on all. been up and down the road plenty of times with old tyre and all was fine. i still have dunlop on back. anyone got any idea why it is doin this.
Old 23-09-10, 09:17 PM   #2
skidmarx
Default Re: new tyre
First thing I'd look at is the back tyre. If it's worn and the profile is squared off, you've effectively raised the front. Front and rear profiles should match within reason. Easy fix, buy a matching rear. Maybe.
Old 23-09-10, 09:42 PM   #3
mulvanny1
Default Re: New Bridgestone BT023, now poor handling.
should also say i have lowerd bike. but last 2000 miles wer fine and its more when i am accelerating.
also dont want to go buy a rear if i dont need to. back tyre is still in good nick
Old 23-09-10, 10:14 PM   #4
Mr Speirs
Mr Speirs's Avatar
Check the tyre pressure on the front. May have been over filled. And whilst you are at it check the rear.
If all is okay then if you have lowered the back then consider dropping the fork through the yokes to get more weight on the front wheel.
Old 23-09-10, 10:35 PM   #5
mulvanny1
Checked the pressure and both are correct, lowered the front by about 10mm
Old 24-09-10, 08:00 AM   #6
neio79
Thats what you get for having bridgestone's on!!!! i have ever only found then ****e with no feel or feedback!!
Old 24-09-10, 08:04 AM   #7
warrenhewitt10
under acceleration? surely thats the rears problem, as no power goes to the front.
I have 2 bridgestone Bt020's on my bike, cant say a bad thing about them, had pirellis on it before, the bridgestones are much better.
Old 24-09-10, 08:08 AM   #8
Stig
That's not exactly a helpful statement. Just because you find Bridgestone’s not to your likely that does not equate to them being a rubbish tyre and subsequently crap on any bike they are fitted too.
Old 24-09-10, 10:22 AM   #9
AndyBrad
Not run in? Pressures? New profile?
Old 26-09-10, 01:18 AM   #10
BanannaMan
BanannaMan's Avatar
Is the front axle seated properly?
Loosen axle and pinch bolt(s) and retighten per specs.
...Bill
BT023 or 2CT what tyre would you have and why? cringer Bikes - Talk & Issues 18 15-06-10 06:11 PM
Bt023 littleoldman Tyres 2 12-06-10 11:30 PM
Handling Nobbylad SV Talk, Tuning & Tweaking 16 18-06-09 12:06 PM
What does Handling mean? Stu Bikes - Talk & Issues 22 17-01-09 10:49 PM
poor visability (or just poor knowledge) gdharbourne SV Talk, Tuning & Tweaking 5 03-12-07 09:39 PM
