Old 24-09-10, 08:55 PM   #1
PuggledPrune
Default Horn wiring question.
I've put in Motrax Hootaz horns on ma SV. Ran a feed from the battery with an inline fuse, and used a relay etc.... just from the info that I could find on th e forum. Then it dawned on me. So I know that I need to connect the horns to the frame for earth but how? I know it seems stupid but lol
Old 24-09-10, 09:42 PM   #2
punyXpress
punyXpress's Avatar
Default Re: Stupid Question
Is the fixing stud the earth ?
Now: Street Triple R
Old 24-09-10, 09:46 PM   #3
Just run a cable to the battery neutral.
Old 24-09-10, 09:54 PM   #4
PuggledPrune
That makes sense. Can I connect to two together first and run just one cable though?
Old 24-09-10, 09:55 PM   #5
You can use a 2 core cable yes
Old 24-09-10, 10:04 PM   #6
PuggledPrune
I'm not sure I know what you mean. The stuff I bought from Halfrauds was multi core - but rated to 20amps or something like that.
Old 24-09-10, 10:07 PM   #7
What did you mean when you said this
Old 24-09-10, 10:16 PM   #8
PuggledPrune
Well to connect to the relay thing I took a feed from each horn, connected them into one spade connector. So to save buying more cable I can use whats left, connect the two horns together and run a single wire from there to the negative terminal.
I know I'm a total noob!
Thanks!!
Old 24-09-10, 10:19 PM   #9
Yeh that should be fine. As long as the cable is the right size for the horns
Old 27-09-10, 09:55 AM   #10
PuggledPrune
Default Re: Horn wiring question.
Great, thanks! All running fine and pretty damn loud! Cheers!
Quick Horn Question Irksy SV Talk, Tuning & Tweaking 7 24-07-10 11:33 AM
02 SVS Light wiring question BanannaMan SV Talk, Tuning & Tweaking 1 01-02-10 10:24 AM
FIAMM Horn question Ceri JC SV Talk, Tuning & Tweaking 11 18-10-07 06:26 PM
FIAMM Horn question JeremySV650 SV Talk, Tuning & Tweaking 11 04-10-06 03:16 AM
Indicator wiring question!! lodman27 SV Talk, Tuning & Tweaking 2 26-03-05 07:13 PM
