Old 01-10-10, 11:01 AM   #1
robstark
Default Exhaust Stuck - Removal Advice
Hi I have a 2005 650S.
I am in the process of trying to remove the exhaust, I have removed (or destroyed) all the the bolts holding the thing on, but is doesnt want to budge, either at the head or the section joint.
I have tried lots of banging with a club hammer and a bit of heat, also pulled back the tabs at the joint and scraped out the gasket but to no avail yet.
Other then bloody mindedness any advice? I was considering placing a jack between the barrels and the exhaust and trying to pop if off with a bit of pressure, whats the worst thing that can happen, maybe bending the pipe a little?
Rob
Old 01-10-10, 12:09 PM   #2
husky03
Default Re: Exhaust Stuck - Removal Advice
you sure the system has been cut already?
Old 01-10-10, 12:47 PM   #3
warrenhewitt10
if its an aftermarket can it should come off in more than one place normally..... is this still the oem exhaust you have on this?
Old 01-10-10, 12:49 PM   #4
Stig
C4
Old 01-10-10, 12:49 PM   #5
robstark
Sorry chap, yes this is completely original equipment (I know cus a brought the bike new back in '05).
Rob
Old 01-10-10, 01:04 PM   #6
Reeder
Are you trying to fit a full system?
Old 01-10-10, 01:29 PM   #7
robstark
No I'm actually trying to remove the swingarm, to look at changing the bearings, however, you cant remove swingarm without first removing exhaust.
Ta
Old 01-10-10, 01:33 PM   #8
When I took off my system I had to pull the front header pipe with all my might with my foot on the front barrel. Once I'd done this, then the system came off, but it was a hard job.
Old 01-10-10, 05:16 PM   #9
TamSV
TamSV's Avatar
As above, as long as you're sure you've got all the bolts off (theres one under the engine on the curvy - I don't recall if the pointy is the same) then it's a bit of a brute force job.
I got a wee bit of movement by pulling the front downipe from side to side, which seemed to loosen it a bit and then knocked the front pipe out with a hammer and piece of wood.
Old 02-10-10, 02:28 PM   #10
Pointy is same enough.
Are you SURE you've got all the bolts out? You know there's one hidden under engine?
Generally they corrode into place in the head. Use a bit of 4x4 and a big hammer to tw*t it from one side to other to loosen it.
Engine removal - stuck, help! muzikill SV Talk, Tuning & Tweaking 26 30-08-10 04:52 PM
exhaust removal elkieboy SV Talk, Tuning & Tweaking 5 19-03-10 03:58 PM
Pointy Exhaust removal s7uyj SV Talk, Tuning & Tweaking 4 12-12-09 10:24 AM
Advice on stuck cam chain... jambo SV Talk, Tuning & Tweaking 3 05-08-08 12:36 PM
SV650s K2 Exhaust stuck rusted on! any advice? alien19779 SV Talk, Tuning & Tweaking 3 06-03-06 12:39 AM
