Old 08-10-10, 05:26 PM   #1
devil1
Default Cam chain rattle?
whats a quick way to stop the rattle
Old 08-10-10, 05:28 PM   #2
Spanner Man
Default Re: cam chain rattle
Good evening.
You can try freeing off the tensioner, by removing it, & giving it a good lube up whilst moving it through its full range a couple of times. Most likely though, you'll need to replace it.
Cheers.
Spanner Man
Old 08-10-10, 05:54 PM   #3
devil1
ok thanks by the way the engine has only done 17k and it only seems to be the front pot will have to take the whole unit out to do it
Old 09-10-10, 02:24 PM   #4
Spanner Man
Good afternoon.
The tensioner is a bit of a fiddle to remove, but you can do it with the engine in situ.
Tensioners can fail at any mileage. I've known of several that have packed up at well under 17k.
Cheers.
Spanner Man
Old 09-10-10, 09:38 PM   #5
keir
mine was near on dead at 8k... although it was 9 years old by this point! changed for a good second hand one at my local garge was £80.
Old 10-10-10, 05:15 PM   #6
KC BRG
buy a new one. u don't want to trust a use part in this case . it may be as bad as what u have or worse.
Old 10-10-10, 05:28 PM   #7
Some rattle is normal
How do you know it was near dead?
Old 11-10-10, 10:50 AM   #8
keir
because it sounded like a ducatti.
Old 12-10-10, 10:50 AM   #9
collis
Default Re: Cam chain rattle?
gonna share a thread as this kinda follows suit.
I was running my bike last night and ran the engine up to about 2500 RPM and i notice a slight rattle comming from the engine, before and past that point all was find so was this the cam chain simply adjusting itself at this point?
Bike runs fine and there appears to be no rattles appart from the vtwin rattle that all bikes get.
Old 12-10-10, 02:03 PM   #10
It is a sleeve inside tensioner that vibrates... 2500rpm must just be the harmonic that it happens to rattle at.
Top end rattle, if not cam chain, what else could it be? Taipan SV Talk, Tuning & Tweaking 8 23-06-10 09:17 AM
timing chain rattle Hazzar SV Talk, Tuning & Tweaking 11 18-08-07 12:54 PM
Odd chain rattle... Stingo SV Talk, Tuning & Tweaking 4 14-03-07 10:24 PM
cam chain rattle yellowsvs SV Talk, Tuning & Tweaking 13 15-11-05 11:50 PM
front cylinder cam chain rattle!! schwantz fan SV Talk, Tuning & Tweaking 17 24-09-04 04:24 PM
