Old 12-10-10, 01:19 PM   #1
hongman
Default Checking front electrics
The other day I nipped into Teco's for something and when I got back out I noticed the little light above the main headlights was still on, even though the ignition was off. Steering lock was on even.
I turned the ignition to the ON position, turned it back off and the light went out.
Has only happened the once so far that I have noticed, and I brushed it off.
The next day (or was it same day) I was riding along and I noticed the High Beam light on my dash was flashing on and off intermittently. Obviously couldnt keep staring at it as I was on the road but I didnt notice it again after that.
I do ride with my lights on day or night.
I am concerned that the light(s) are going to stay on again, me not noticing and coming back to a flat battery.
Since this is now 2 odd things happening around the front of my bike I thought it might be best to check it out.
I did a quick visual check and although the loom looks a bit grubby in places, I cant see any chafing/breaks.
I have a multimeter but have no idea how/where to test
Runs ok as far as I know, no known problems.
Any advice?
Old 12-10-10, 01:22 PM   #2
warrenhewitt10
Default Re: Checking front electrics
the usual points on the curvy that are prone to shorting things out? under the front seat i belive....
dont own a curvy myself i'm afriad...
Old 12-10-10, 02:12 PM   #3
MrMessy
I had a similar problem on my 1st curvy. The rear wiring had shorted out when it rubbed on the front seat mounting bar. What I had not realised, it had melted the insulation on the wiring to the handlebar switch and eventually caused the side light to come on all the time the ignition was on. I partied and reinslated the wires and this cured the problem.
MrMessy is offline   Reply With Quote
Old 12-10-10, 02:37 PM   #4
hongman
Ok thanks - I will have a better look soon, hopefully tomorrow.
Old 12-10-10, 02:40 PM   #5
punyXpress
punyXpress's Avatar
Sure you hadn't turned the key an extra notch ( to 'P' ) ?
Now: Street Triple R
Old 12-10-10, 03:01 PM   #6
warrenhewitt10
i thot that was too simple to suggest....
but i suppose you never know
Old 12-10-10, 03:03 PM   #7
SoulKiss
SoulKiss's Avatar
+1, exactly what I was going to suggest
Old 12-10-10, 03:04 PM   #8
hongman
Um.....
Er.....
Shhhhhhhhh....
I didnt even notice the P til you mentioned it, and yes, I think that is what I done.....
Old 12-10-10, 05:59 PM   #9
hongman
On the way home today I noticed that my left headlight is out
Might get a pair of those Osram Nightbreakers, they get good reviews.
Old 12-10-10, 06:03 PM   #10
warrenhewitt10
HID's are the way forward dude
Checking my oil level Mattnut Bikes - Talk & Issues 23 05-03-09 08:31 AM
Checking in Kalessin Idle Banter 15 15-01-09 11:27 PM
Checking the carbs metalmonkey SV Talk, Tuning & Tweaking 14 07-04-08 01:23 PM
Checking out the front brake calipers on my new-to-me naked MartinM SV Talk, Tuning & Tweaking 4 02-01-08 12:43 PM
Checking in Grifter SV Talk, Tuning & Tweaking 9 22-01-05 06:47 PM
