15-10-10, 11:36 AM | #1 |
Indicators not working properly.
My indicators work fine at a standstill, with the engine running. Once I get moving, the RHS indicators won't work - they light up for about 1/2 a flash, then won't relight. The LHS indicators then won't work for around 30 secs, after which they're ok. Once I've been moving, the problem continues even with the bike at standstill, until I turn the engine off and restart.
Bike is a naked curvy (99). I have a Givi Wingrack with integral indicators fitted, but all was working fine until yesterday! Any experience/thoughts/input/wisdom? |
15-10-10, 02:49 PM | #2 |
Re: Dodgey indicators
id say its a simple connections issue, check the wiring
15-10-10, 04:15 PM | #3 |
yeah, sounds like a loose connection to me
K4 trackbike, a black K8 S loaded with my spares and a 1989 CBR 400 TriArm with all the trimmings. |
15-10-10, 05:19 PM | #4 |
IF you've not changed anything recently then probably a loose connection.
I had a similar problem however - indicators would work (on my pointy) perfectly fine as long as the rev's were below +-2500rpm. As soon as I moved off or the revs climbed, all indicators would stop working. In the end it was the flasher relay - the replacement was a pattern piece for a Bandit (from wemoto.com) that seemed to work fine except for this somewhat random problem. A £70 (!!) SV650 relay and problem disappeared. Good luck! |
Fitted new indicators - not working. | devil1 | SV Talk, Tuning & Tweaking | 3 | 03-04-10 05:24 PM |
Do things yourself if you want 'em done properly! | thulfi | Idle Banter | 6 | 12-02-10 10:04 PM |
New indicators fitted - not working right. | wilky007 | SV Talk, Tuning & Tweaking | 8 | 21-02-09 04:31 AM |
Both right side indicators not working ;( | drefraser | SV Talk, Tuning & Tweaking | 22 | 05-11-07 09:58 PM |
Have you ever punched someone properly? | thor | Idle Banter | 53 | 26-05-05 04:29 PM |
