Old 20-10-10, 12:06 AM   #1
FG1
Default Broken external hard drive
A mate has an external hard drive with loads of music and photos on. Unfortunately it has given up on him. Is there a way of retrieving the contents?
Old 20-10-10, 12:15 AM   #2
speedplay
Default Re: Broken external hard drive
Yes but not cheap.
Is it the power supply or the drive itself?
If it's just the power supply it's a simple job of just plugging it into a pc or another external body.
If it's the drive, that's where it can get costly.
Old 20-10-10, 04:21 AM   #3
FG1
As far as I know it's the drive.
Old 20-10-10, 07:22 AM   #4
collis
chances are it could be the enclosure, does it make any ticking noises when running or it is quiet and simply will not read?
What sort of drive is it? (ie big - the size of a cdrom drive, or Small - the size/smaller of a floppy disk drive)
Old 20-10-10, 08:46 AM   #5
benji106
If its a standard hard drive in an enclosure, i.e. not a solid state, likely that the bearings are knacked so it wont spin up any more. I have heard that putting the drive in a freezer can bring it back to life temporarily, possibly long enough to get some stuff off it.
Old 20-10-10, 12:29 PM   #6
JamesMio
Tony - these guys are friends of mine and can almost certainly help:
Hard drive data recovery from Kingdom Data Recovery
Give them a bell and I'm sure they'll keep you right.
JM
"That **** on the push-bike."
Creatomatic
Old 20-10-10, 01:07 PM   #7
Quiff Wichard's Avatar
a "friend" ?
"special" stuff on the hard drive..
take it to the police they will get it off it in minutes..
Old 20-10-10, 01:30 PM   #8
SoulKiss
SoulKiss's Avatar
There's more to it than just bunging it in the freezer, google the process before you do it
Old 20-10-10, 01:38 PM   #9
collis
a "friend" ?
I got the same software as them, it's very good at it's job i'll give you that.
Old 20-10-10, 05:01 PM   #10
The Guru
Originally Posted by collis View Post
I got the same software as them...
Whats that then?
Recommend my a external hard drive Girth Idle Banter 13 13-05-10 11:47 AM
New Hard Drive - Noise? 600+ Idle Banter 3 30-03-09 06:17 PM
Which External Hard Drive? Miss Alpinestarhero Idle Banter 48 10-02-09 08:12 PM
external hard drive advice please embee Idle Banter 11 28-05-06 12:05 PM
pc hard drive question will Idle Banter 6 15-05-06 02:38 PM
