Old 22-10-10, 04:10 PM   #1
SUPERSTARDJ01
Default Tyre pressure/handling question?
Hi,
Would 4psi down on front and rear tyres make the bike handling ****e? Because the ZX felt as though it was running on a flat, stopped checked front tyre no puncture no nails only 4 psi down, so pumped it up and still the same although if I go faster the feeling seems to go, the brakes are sqeaking but it's not hard to push at all, could the brakes be binding making it pull slightly to one side, giving the feeling of a flat tyre?
Old 23-10-10, 10:58 AM   #2
Default Re: Quick handling question?
You can probably notice 4psi
the brakes binding cannot make it pull to one side, neither does a flat tyre
Old 23-10-10, 11:26 AM   #3
fizzwheel
fizzwheel's Avatar
4 psi is probably enough that you'd notice it.. Not sure why your bike is handlnig strangely, but check the basics so
1. tyre pressures
2. type profile ( i.e. not gone square )
3. Suspension settings - have you tweaked or fiddle with them and induced the handling characteristic that way.
Old 23-10-10, 09:11 PM   #4
barwel1992
Default Re: Tyre pressure/handling question?
wheel alignment ?
twisted forks ?
only things i have experience that make the bike go to one side
Old 23-10-10, 09:14 PM   #5
Mirrors ok?
Old 23-10-10, 09:21 PM   #6
busasean
check the head/wheel bearings
Old 24-10-10, 05:58 AM   #7
SUPERSTARDJ01
Wheel bearings seem ok, suspension not touched, tyres not squared, head seems to have a little movement, how do I check forks are not bent?
Old 25-10-10, 01:52 PM   #8
johnnyrod
johnnyrod's Avatar
4psi down on the front would feel pretty horrible, are you sure the extra air is still in it?
Old 25-10-10, 02:11 PM   #9
SUPERSTARDJ01
Yep pumped up riden left for the day re-checked with digital pressure guage and still on 36 psi, I have how-ever noticed my wheel is pointing slightly left, so forks maybe twisted slightly.
Old 26-10-10, 09:29 AM   #10
johnnyrod
johnnyrod's Avatar
try this
www.bikeguru.co.uk/forks.html
tyre pressure JamoSV650s SV Talk, Tuning & Tweaking 1 20-06-09 11:27 PM
Tyre Pressure evilexel SV Talk, Tuning & Tweaking 5 20-02-09 10:57 PM
New rear tyre but same old one on front - any potential handling issues? Paul the 6th Bikes - Talk & Issues 18 24-11-08 05:04 PM
How much?(tyre pressure) Jussi Tyres 4 26-07-07 08:07 AM
Diablo tyre pressure question.. griggsy SV Talk, Tuning & Tweaking 6 17-06-06 07:54 PM
