Old 11-11-10, 06:40 PM   #1
Orpheus
Default Front tyre lasting less than rear?
I would have thought normally a front lasts longer than a rear, but the fron seems to be worn down sooner. Both were changed with a month, front is probably near to limit, rear seems to have quite a bit left.
Is there anything that could be causing this? Just concerned that it could indicate antother underlying fault.
Thanks.
Old 11-11-10, 06:47 PM   #2
steve.w
Default Re: Front tyre lasting les than rear?
Do you ride the front hard? aggresive counter steer,heavy front braking maybe.
Old 11-11-10, 06:52 PM   #3
G
Depends on the tyre. The BT021 & BT023 bridgstone's are well know for doing that.
6.67300 × 10-11 m3 kg-1 s-2
Old 11-11-10, 06:53 PM   #4
Biker Biggles
Biker Biggles's Avatar
My fronts last twice as long as the rear,and always have on every bike Ive owned.I suppose its mostly down to riding style assuming you have the same tyres front and back.Do you habitually push the front into corners,do lots of heavy braking or do lots of trackdays?
Old 11-11-10, 06:58 PM   #5
Orpheus
Yep, BT021's. That sheds some light then, as i wouldn't say i'm a particulary aggressive rider. 90% commuting.
Old 11-11-10, 07:00 PM   #6
G
My front and rear BT021 went at the same time... They are a **** tyre too.
Mystery over... Buy another brand problem solved.
Old 11-11-10, 07:27 PM   #7
Orpheus
Default Re: Front tyre lasting less than rear?
Have you tried the Roadsmarts? Thats what i originally wanted, but they didnt have them in stock.
Old 11-11-10, 07:54 PM   #8
Roadsmarts are spot on, got more than enough grip in the dry and wet.
A couple of quid cheaper than the bridgestones too.
New rear tyre but same old one on front - any potential handling issues? Paul the 6th Bikes - Talk & Issues 18 24-11-08 05:04 PM
Longest lasting? ljharmitt SV Talk, Tuning & Tweaking 33 02-10-08 12:24 PM
Front and Rear tyre Grinch Stuff Wanted 4 15-07-08 08:51 AM
Best place to buy and get fitted rear and front tyre? rwoodcock01 Tyres 4 19-07-07 09:21 PM
GSXR front end swap - front tyre profile. Khewett SV Talk, Tuning & Tweaking 12 11-05-06 11:24 AM
