Old 06-12-10, 04:47 PM   #1
AndyBrad
Default Datatool system 3 battery question
I want to take the battery off my bike for the next month (or till the ice goes) however its gotn a datatool on it. Is there any way to remove the battery without the alarm beeping every 15 seconds?
Old 06-12-10, 04:59 PM   #2
AndyBrad
Default Re: Datatool system 3 battery question
Sorry obviously a glitch in the matrix, please delete the other ones.
Old 06-12-10, 05:06 PM   #3
B1k3R
You could try the anti spike procedure. Never tried it mysef but:
Use these if the alarm system has been spiked.
1. Remove lid from main alarm unit.
2. Remove internal battery link from PCB (arrowed)
3. Remove alarm inline fuse
4. Unplug PCB from alarm loom
Leave these parts out over a period of at least 6 hours, to allow the system to
drain completely.
To refit
With the bikes battery still in place and fully charged.
1. Plug PCB onto loom and reinstall
2. Replace In-Line fuse.
3. The alarm will sound for a period of approx. 30 seconds.
4. Allow the system to reset itself.
5. Replace internal battery link onto PCB.
6. Make sure all connections are complete and replace lid
7. Disarm system as normal (this may take up to 3 presses as system realigns itself)
Old 06-12-10, 05:22 PM   #4
B1k3R
Oh and get yourself some zapper batteries. Each zapper takes 2 batteries. Bargain
Here
Old 06-12-10, 05:29 PM   #5
speedplay
Just take the datatool out
Simple.
Old 06-12-10, 07:00 PM   #6
I would remove the alarm as they're so bloody annoying.
Don't remove the battery or the alarm will die in an annoying way and you'll need to remove it.
If you are maintaining battery then run the optimate lead outside or something.
Old 06-12-10, 07:06 PM   #7
Dave20046
Dave20046's Avatar
buy a charger/maintainer. An optimate/maximiser type product.
Old 06-12-10, 07:14 PM   #8
speedplay
Took my alarm out and wrapped it in a blanket and left it to scream to a muted death in the corner of the shed
Old 06-12-10, 07:17 PM   #9
B1k3R
But you have to connect the battery lead. I have a waterproof AccuMate TM71 which I haven't fitted yet. I also have a datatool 3 alarm so to get the lead fitted I am going to have to disconnect the battery at some point.
Old 06-12-10, 09:02 PM   #10
Holdup
then just bung the alarm in service mode untill the lead is fitted, shove a screwed up towl or something over the alarm to quieten (is that a word?) it a bit
Datatool System 4 Red TSM Bikes - Talk & Issues 47 23-09-21 06:20 AM
Datatool system 3 PIN? nobby SV Talk, Tuning & Tweaking 15 23-03-09 10:17 PM
datatool system 3 evertheoptimist SV Talk, Tuning & Tweaking 17 02-06-08 10:05 PM
Datatool system 3 suzsv650 Bikes - Talk & Issues 1 04-07-07 01:26 PM
Datatool System 3 TSM SV Talk, Tuning & Tweaking 1 16-07-05 11:48 AM
