Old 09-01-11, 03:48 PM   #1
shelleyamy
Default Pointy lower fairings fitting
A friend has bought a second hand (but unused) set of lower fairings for his 2007 SV.
They came with an incomplete fitting kit, and a couple of bit’s that aren’t shown on the contents picture of the instructions.
The bits not shown on the instructions are the 2 brackets, which I think attach to the radiator.
Anyone have a picture of how the fitting kit fits under the fairing, or can say what bits are missing.
Thanks
Mike
Old 09-01-11, 04:15 PM   #2
christopher
christopher's Avatar
Default Re: Pointy lower fairings fitting
This is one of mine (2005 K5). I'm pretty sure the K5+ share the same radiator so will use the same mounting brackets, but the K3/K4 have a wider radiator so don't use/need them. Don't take that as fact, just something I recall reading. Anyway, pictures...
Oh and I'd get some crash bungs which replace the OEM main brackets... they snap too easily if you have the OEM bungs on them:
http://forums.sv650.org/showthread.p...32#post2188174
http://forums.sv650.org/showthread.p...33#post2188375
christopher is offline   Reply With Quote
Old 09-01-11, 06:07 PM   #3
there are a lot of parts missing from that kit.
faring bolts and spacers
radiator u brackets like above (there are 2 types on for K3 and one for K3>)
bottom to frame/engine brackets
main bracket bolts to hold the large discs in place
side to side fitting bridge (black plastic part with 4 holes) plastic pop rivets.
what you dont need are the funny looking brackets in the picture as they are for the nosecone and your bike will already have them.
Old 09-01-11, 06:24 PM   #4
Owenski
+3
http://forums.sv650.org/showthread.php?t=161389
Old 10-01-11, 10:12 AM   #5
shelleyamy
Their the ones showing on the parts list,so missing them.
Thanks,Mike
Old 10-01-11, 10:18 AM   #6
shelleyamy
Not looking good then.
Isn't that showing in the picture(with 2 of the rivets already in it)?
Anyone want to swap for the right ones?
Thanks,Mike
Old 10-01-11, 07:37 PM   #7
Nobbylad
Nobbylad's Avatar
Thanks,Mike
If you're just after them, get down to B&Q and get some strip ally and then make them yourself, dead easy.
http://forums.sv650.org/showthread.p...unting+bracket
Fitting 99-02 oem lower fairings Makalux SV Talk, Tuning & Tweaking 14 05-03-16 08:23 PM
Fitting lower fairings to curvy degsy SV Talk, Tuning & Tweaking 6 19-05-10 09:51 PM
Lower fairings fitting kit joshua02 SV Talk, Tuning & Tweaking 3 06-05-10 01:20 PM
K4 Lower Fairings Fitting Kit booner Stuff Wanted 0 27-07-07 03:31 PM
Fitting lower fairings bikerskez SV Talk, Tuning & Tweaking 8 24-12-04 10:51 PM
