Old 14-01-11, 07:35 PM   #1
Teejayexc
Default 650 or 1000?
Tried to do a search, but hit by everything but
So basically, I currently have a 650S and am thinking of changing to 1000. Apart from the obvious what are the thoughts of anyone who has done this, or vice-versa and why, and riding position/comfort differences etc.
Tia, Tj
Old 14-01-11, 07:41 PM   #2
mattSV
mattSV's Avatar
Default Re: 650 or 1000?
Two totally different bikes, lots of threads on here already covering it
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 14-01-11, 07:58 PM   #3
barwel1992
not done it but from my understanding
thou uses a fair bit more fuel than the 650
thou has loads of power and torque
650 handles better (when equipped with proper forks like the thou)
thou is heavier
other than that i cant help
Old 14-01-11, 08:56 PM   #4
Berlin
2006 Suzuki SV1000SZ
Overall Length: 2,085 mm (82.1 in)
Overall Width: 745 mm (29.3 in)
Overall Height: 1,170 mm (46.1 in)
Seat Height: 800 mm (31.5 in)
Wheelbase: 1,430 mm (56.3 in)
Ground Clearance: 150 mm (5.9 in)
Dry Weight: 187 kg (412 lbs)
Engine type: Water-cooled 996 cc four-stroke 90° 8 valves V-twin, DOHC, TSCC. 123 hp (91.7 kW)/ 8,500 rpm, 102 Nm/ 7,000 rpm.
TECHNICAL SPECIFICATIONS:
Wheelbase: 1,430 mm
Seat Height: 800 mm
Dry Mass: 187 kg
Fuel Capacity: 17 litres
ENGINE:
Engine Type: 90-degree 4-stroke V-twin, DOHC, liquid cooled, electronic fuel injected, 4 valves per cylinder
Bore x Stroke: 98.0 x 66.0 mm
Max Power: 125.1 PS
Max Torque: 102 Nm @ 7,500rpm
Piston Displacement: 996cc
Compression Ratio: 11.6:1
Carburettor: Fuel injection 52 mm
Lubrication: Wet sump
CHASSIS:
Front Suspension: Conventional 46 mm telescopic. Fully adjustable
Rear Suspension: Link type, coil spring, oil damped, fully adjustable
Rake/Trail: 24.5 degrees / 99 mm
Front Brake: 4-piston calipers, 310 mm dual discs
Rear Brake: Singel-piston caliper, 220 mm disc
Front Tyre: 120/70R15
Rear Tyre: 180/55ZR17
SV 650 S 2005
Overall Length: 2,080 mm (81.9 in)
Overall Height: 1,085 mm (42.7 in)
Wheel Base: 1,440 mm (56.7 in)
Dry Weight: 165 kg (363 lbs)
Engine type: Liquid-cooled 645 cc v-twin DOHC, 8 valves. 72 hp (53 kW)/ 9,000 rpm, 84 Nm/ 7,200 rpm.
thou is heavier
Unless the thou has the same fork conversion then they both handle the same
The Thou is for those who can't be bothered to add hot cams, do 'Busa piston swaps etc
I'd love to do a "minitwin race spec chassis" for the thou on the road. It'd be *beast* as the young 'un say. Total weight strip and race fairing, USD forks, Penske rear shock, Underseat exhaust etc.
In fact, I might just have my next project
Old 14-01-11, 08:57 PM   #5
coolevilangel
get a thou lol
Old 14-01-11, 09:09 PM   #6
barwel1992
the forks on the thou are cartridge forks
Old 14-01-11, 11:08 PM   #7
nope RWU up forks
Swaps are common for GSXR 1000 fronts
Speak to Dave Preston he's had both in sucession
Old 14-01-11, 11:11 PM   #8
barwel1992
just because they are RWU does not mean they are not cartridge all that means is the orientation of the forks.
Old 14-01-11, 11:14 PM   #9
Unless YC has been at them, no
http://www.suzukicycles.org/SV-serie...-SV1000S.shtml
CHASSIS:
Old 14-01-11, 11:37 PM   #10
barwel1992
im not saying they are cartridge but im saying you do get RWU cartridge forks
any how they are cartridge ..... LINK
looking for sv 1000 The juj Stuff Wanted 4 14-04-10 06:24 AM
Rbl 1000 punyXpress Pennine Massive 9 07-05-09 05:42 PM
Sv 1000 Graciepants Pennine Massive 11 20-03-09 08:00 AM
T R E for sv !1000 evertheoptimist SV Talk, Tuning & Tweaking 4 12-10-08 10:14 AM
sv 1000 BigglesBird Idle Banter 4 07-01-70 09:25 AM
