Old 20-01-11, 01:17 PM   #1
Drumming_Animal
Default Gear lever/boot wear.
Well i seem to have come up with a problem....
The gear lever on my pointy bit the dust last year and so i replaced it with one of the ones thats on ebay (the metal tipped ones that fold back) not a bad little lever apart from the fact that it appears to have eaten through the rubber sole on my boot. Whenever i wear trainers it starts to go through them over time aswell. Tad annoying obviously.
Im looking at getting some new boots this year and i dont want the sole eaten through after a couple of months of riding.
There is, after searching, rubber tipped gear levers but they appear to be for curvys. Will they still fit and work like they should on a pointy?
Cheers in advance
Old 20-01-11, 01:40 PM   #2
Owenski
Default Re: Gear Levers...
pushbike innertube and 2 cable ties rubber coat the one you've got.
Regarding the curvy/pointy compatbility I have no idea.
Happy to be of no help
Old 20-01-11, 03:37 PM   #3
I kno which levers you mean. Got one on my curvy.
I'm thinking of using rubber if it gets any worse with the boots.
Old 20-01-11, 04:04 PM   #4
SVMAT
File grooves in and use some 4-5 o-rings :P looks the part aswell
Old 20-01-11, 04:11 PM   #5
bigchris
Slide some fuel hose over it, works a treat
Old 20-01-11, 04:34 PM   #6
toby_smith
Simpler than all of those. Chuck a could of layers of insulating tape around it. Job done.
The shiney metal ones on ebay look tacky as f*ck anyway, covering the end of it will be an improvement
Old 20-01-11, 05:02 PM   #7
Drumming_Animal
nice, im liking the o-ring idea best, i think ill give that a go
cheers
Boot spares. Can I buy a gear change rubber anywhere? monkey Bikes - Talk & Issues 6 12-05-10 11:20 AM
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
