Old 21-01-11, 12:43 PM   #1
jim c
Default water pump problem?
hi all,can anyone help me.ive noticed that when i take my oil filler cap off theres a white emulsion on it.does this mean that the water pump seals are gone?there is no sign of water in the oil in sump so hoping that its not head gasket.if it is the pump does anyone know where i can purchase o-rings and crankshaft gasket from in the uk.thanks to all.....jc.
Old 21-01-11, 01:03 PM   #2
barwel1992
Default Re: water pump problem?
mine is the same, but never had milky oil or water
Old 21-01-11, 03:17 PM   #3
jambo
jambo's Avatar
Originally Posted by jim c View Post
water pump problem?
Probably not.
Presuming all is as you've described, that is that there is a small amount of emulsified oil on the inside of the oil cap, but that the oil itself (and indeed the coolant) are both clear an normal looking then this is likely some condensation on the inside of the motor.
Short journeys tend to mean all the water vapour in the motor doesn't have time to leave the system entirely, leaving you with what you see.
Jambo
Old 22-01-11, 11:05 AM   #4
jim c
thanks for the replys.shall keeo an eye on it....mon the good weather.....
Old 22-01-11, 11:29 AM   #5
barwel1992
im going to clean it off and see if it comes back, i have new head/base gaskets on mine so will be interested to see if it builds up again
Curvy Water pump SVDragRacer Stuff Wanted 2 22-03-09 11:58 AM
K2 Water Pump Housing andy1505 Stuff Wanted 2 06-02-08 01:33 PM
Water Pump....leak 21QUEST SV Talk, Tuning & Tweaking 9 07-11-07 09:02 AM
Water pump on VW Passat rpwoodman Idle Banter 11 08-05-06 06:15 PM
Water Pump Leak greeno76 SV Talk, Tuning & Tweaking 2 24-04-05 04:56 PM
