Old 22-01-11, 08:50 AM   #1
ImplodedHamster
Default Pointy restriction methods?
Hiya,
i have seen a few ECU restrictors for sale that fit a K3 recently, mine is restricted but seems to have a throttle stop not a different ECU (only opens about 1/3 to 1/2) is this normal?
Thanks
IPH
Old 22-01-11, 10:07 AM   #2
Swer
Default Re: Restrictor
Hi,
I have k5 and the go slower washer in too along with the throttle stop, which dose that exactly, only lets you open half of it , but it still rev's up fully if you have a long enough road to wait for it. HTH
Old 22-01-11, 01:45 PM   #3
Scorpio
Question Re: Restrictor
Hi,
Newbie question here so be gentle
Just collected a Curvy last night. All seems fine on a short test ride in a 30mph area
How do I tell if it has a restrictor kit fitted, what / where does a restrictor go (is it in the ECU, or an engine / exhaust bolt-on ?)
I had a quick search but didn't see any definite answer.
thanks folks
Old 22-01-11, 01:48 PM   #4
tom-k6
you will feel if it has a throttle stop on it, and if its an ECU restriction, you'd need a decent long straight road, and the restriction will kick in about 8K rpm and you will really feel the bike just stop revving and acceleration will become non-existant.
Old 22-01-11, 02:08 PM   #5
Scorpio
Thanks for the info. The bike was reving fine but I only took it to about 3k as there was frost on the road Didn't check where throttle hits the stop.
Sounds like I'll be able to tell more once I find a decent bit of road.
cheers
Old 22-01-11, 02:18 PM   #6
hongman
Well you can test the throttle stop without having the bike running
Old 22-01-11, 02:50 PM   #7
Swin
Swin's Avatar
A curvy wouldn't have ECU restrictors as they are carbed aren't they? I think the restrictors to a curvy are washers in the inlets - as Tom says, you'd feel that a throttle stop has been put on even without the engine running
Swin is offline   Reply With Quote
Old 22-01-11, 05:08 PM   #8
ImplodedHamster
swin is right about the curvy restrictor, there are washers to prevent to much stuff in the carbs
and thanks its good to know its normal :P
Old 22-01-11, 05:10 PM   #9
robbie09
If it does an indicated 120...pretty sure it wouldn't be restricted! :P on private roads of course .
Curvy has the washers no ECU restriction!
Old 22-01-11, 06:07 PM   #10
ImplodedHamster
a restricted bike should do about 90... mine seems to do an indicated 100 tho ( again, private land :P )
not complaining tho
Dirrerent showering methods for men and women Specialone Idle Banter 15 14-10-10 03:39 PM
Servicing methods, what do you do? thefallenangel Bikes - Talk & Issues 30 16-09-09 10:43 PM
Pointy FI International Restriction K3 Sally For Sale - SV's and SV related items 5 13-03-09 06:16 PM
Alternative methods of removing rivets. ejtrent SV Talk, Tuning & Tweaking 6 02-11-07 05:25 PM
Air supply :: Tank spacers :: Other methods snoopy SV Talk, Tuning & Tweaking 38 07-01-05 06:38 PM
