Old 04-02-11, 04:56 PM   #1
vardypeeps
Default Wonky after blown over!
Afternoon.
I've got a SV650s K4 and I'm loving it.
Long story short it got blown over today and I seem to have gotten away with very little damage. No scratches or dents apart from the exhaust can which I'm replacing anyways.
Main reason why I'm posting is that the yokes do not seem to be in line now? The forks look straight but when travelling in a straight line I'm turning to the left!!!
To fix this is it just a simple case of loosen all the clamps for the forks and the top yoke nut and realign?
Thanks for your info in advance.
Old 04-02-11, 04:57 PM   #2
Default Re: Wonky after blown over!
Yeah should be, maybe a clipon got knocked around a bit or bent, that can give illusion too.
Old 04-02-11, 05:07 PM   #3
vardypeeps
Cool beans. It looks like the mirror has taken a lot of the weight of the bike as it's bent down a little, also the front sub frame is going to need a little helping hand to get it back where it should be.
Old 05-02-11, 09:01 AM   #4
mikerj
I know it sounds obvious, but don't undo all the fork clamps with the weight of the bike on the front wheel...
Old 05-02-11, 09:55 AM   #5
IMO, having had this exact same thing, only undo the top pinch bolts, you can then jostle them back into normality.
You could even put front wheel against a wall if it needs more persuasion.
All they have done is twist in the yokes and stay there, once released they should go back.
Old 05-02-11, 10:04 AM   #6
sauluk
Forks prob not bent but could have twisted in the yokes. Dno if that's what people are saying above!
Old 05-02-11, 10:05 AM   #7
sauluk
Ha, I really should have read the whole of the post above!
Old 07-02-11, 08:47 AM   #8
vardypeeps
Needed to fit a new chain and sprockets on the weekend and eventually got round to straightening everything up. Don't think I needed to but I loosened the top yoke nut just to make sure the forks could move, it needed quite a bit of force but looks like I'm all good now.
Wonky front end dirtydog SV Talk, Tuning & Tweaking 35 16-05-10 08:53 PM
yam divi wonky wheel davepreston Bikes - Talk & Issues 8 30-04-09 01:20 PM
Best of luck to my Wonky Knee'd brethren. K Idle Banter 12 19-12-06 12:15 PM
wonky knee hovis Bikes - Talk & Issues 5 01-12-06 03:11 PM
Wonky Exhaust! Bear SV Talk, Tuning & Tweaking 24 16-11-06 06:10 PM
