Old 06-02-11, 05:52 PM   #1
alexwitham
Default Total Power Loss - Fuelling Issue?
Hi Guys,
Encountered my first problem with the SV today. Help/Advice would be greatly appreciated.
I was riding in 5th/6th gear at about 80mph keeping a steady throttle and all of a sudden the bike totally lost power. Imagine what your bike feels like when she's running out of fuel - that's what it was like. The bike didn't cut out, I pulled the clutch in and tried to blip the throttle - the bike would not rev at all. I coasted to a halt after knocking it down into first gear, tapped it into neutral and left the bike to idle for about 15 seconds. After a moment had passed I started to introduce some throttle, she felt OK at this point and so I pulled away and it was absolutely fine.
The bike was hot (had been riding for about 25 miles) and had a good gallon or more of fuel in it.
After another 10-20 miles the same thing occurred again. About 90mph, half throttle in top gear. Exactly the same issue as above. Again, sub 1 minute of idling and I was on my way once more. Again the bike was hot and had plenty of fuel.
I'm thinking it's a blocked breather / perished fuel hose / blocked fuel filter (does the SV650S 1999 have one?) or similar. What do you guys think?
Thanks fellas.
Alex.
Old 06-02-11, 06:05 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Total Power Loss - Fuelling Issue?
Not cold enough for carb icing so I think your fuel starvation theory sounds favourite.
Old 06-02-11, 06:06 PM   #3
alexwitham
Does a 1999 SV650S have a fuel filter? are they vacuum fed or fuel pump?
Thanks,
Old 06-02-11, 06:09 PM   #4
bigchris
Thanks,
Yes, filter bolted to underside of tank ( at the back on the left side as you look at tank while riding ).
Fuel is vacuum fed into a mechanical fuel pump located at the front right of bike bolted to the inside of frame.
Old 06-02-11, 08:35 PM   #5
alexwitham
Just gone and whipped the tank/airbox off. It looked like the tank breather hose was kinked, will give an update if it has not cured the problem.
Thanks,
Varadero 125 fuelling issue Neeja Bikes - Talk & Issues 4 31-07-09 08:23 PM
YZF750 fuelling issue Stig Bikes - Talk & Issues 5 21-02-09 12:09 PM
total loss ignition twonky SV Talk, Tuning & Tweaking 11 28-01-09 02:51 AM
Total loss electrical system - Can I fit a brake light? DarrenSV650S Bikes - Talk & Issues 7 07-07-08 09:38 PM
Insurance 'total loss' 21QUEST Bikes - Talk & Issues 17 07-03-08 09:44 PM
