Old 10-02-11, 08:53 PM   #1
muzikill
muzikill's Avatar
Default Suzuki sv 650 greases & fluids equivalent list
I've noticed there arent many posts about this & posts available have a lot of conflicting information so i thought i would post a list up - i will edit it if there any mistakes. Posts are welcome to update any unknowns i have listed with updated info. As you know i am in the process of a engine rebuild and this would help me and others for future use & possibly save money having to buy the 'official' tubs and tubes.
Oem prices vs. alternative also shown.
  • Molybdenum oil solution = 50/50 mix of molybdenum grease & m/c engine oil
  • Suzuki bond 1207b (us) / 1215 (uk) £38.32 = Threebond liquid gasket- 1207b £15 / 1215 £20
  • Thread lock 1342 £47.21 = Three bond 1342 £3-£5, Permatex thread lock (blue) medium strength (or equivalent)* around £5-£10
  • Thread lock super 1303 = Three bond 1303 £3-£5, Permatex thread lock (red) high strength* around £15
  • Suzuki super grease A = ?
  • Suzuki moly paste £8.54 = ?
* When looking at other alternatives for threadlock check first as some manufacturers don't use the same colours/strengths combinations!
Old 10-02-11, 08:55 PM   #2
muzikill
muzikill's Avatar
Default Re: Suzuki sv 650 greases & fluids equivalent list
I also found this guide posted by TSM in another thread which i thought would be handy to keep in here once it's all sorted out.
LM Grease
A lithium based high melting point grease specifically designed as a wheel bearing grease.
Moly Grease
Molybdenum grease for use on kingpins, shackles...etc. Also used in engine re-assembly on items like main and camshaft bearings.
Red Rubber Grease
Special rubber compatible grease for use on hydraulic brake and clutch components where hardening or swelling must be avoided.
CL Grease
Soft calcium based grease for chassis lubrication and for swivels and spring shackles. Resistant to salt water spray.
BNS Grease
Bertone based non-melting high temperature grease for ultra severe applications such as race/rally front wheel bearings.
MS3 Grease
A high melting point lithium based grease for heavy duty chassis and some CV joints.
Copaslip Grease
Ideal for manifold studs, cylinder head bolts, spark plugs and wheel studs. Prevents corrosion
Old 10-02-11, 10:25 PM   #3
RRG
ZX1 SG http://www.team-zx1.com/Super-Grease
pretty much covers all your lube needs. if you dont do a lot of 'rubber' parts then a small tub of RRG is all you need i have a tiny pot of it and it goes a looooong way as you just need a 'smear and rub'.
the ZX1SG covers just about everything that needs grease.
threadlock i only use the blue by starlock. never tried the threebond so cant comment.
Old 10-02-11, 10:37 PM   #4
the 100g tubs of RRG on ebay are big enough, I used about 10g of the tube (being very liberal).
That grease sounds like lab developed version of the old duchams bearing grease
Old 28-02-11, 09:31 PM   #5
muzikill
muzikill's Avatar
RRG
so i could use this stuff for everything? - eg the drive shafts, gears, camshafts, pistons etc.....
Old 28-02-11, 09:40 PM   #6
No, use moly oil where it's called for on reassembly. I don't trust those snake oils, especially not at that price.
Where it calls for suzuki super grease use a lithium complex grease from bearing or engineers supplier, it's dead cheap, like a quid a tube, and good for chassis bearings and such.
A few tricks;
Don't refit the clutch and oil pump until it's back in the bike and you're ready to almost spin it over. Starting with some cheap 10w40, lean the bike a way to the left and pour some into the oil galleries under oil pump.
Don't fit spark plugs, disconnect the coil LT leads. When fully reassembled spin the motor over for a few 10-15s bursts a few minutes apart until the oil light goes out to prime the oil system. Having the plugs out massively reduces the force on big end and main bearings.
Old 28-02-11, 09:44 PM   #7
the zx1sg will cover anything that needs grease. have a look on the website.
rrg for rubber stuff
any 10w-40 bike specific oil for your engine. my preference is millars but thats me.
i also use ZX1 micro oil and have been for yeeeeeears some say its snakeoil but i use it and it works. (dont use it if you are running in a vehicle)
another couple of greases you might consider is silicon grease for the plug caps and contact grease for electrical connectors.
up to you in the end what you use.
Old 28-02-11, 09:47 PM   #8
£12 vs £1.50 for a tube of grease, I couldn't justify that.
If it was so good they'd be using it in industry and you'd be able to get it anywhere.
Regarding threadlocks I use the loctite stuff, 242 GP threadlock is fine for 99% of stuff, 620 for putting bearings in that need locking so you need heat to get them out. But there are loads of products that fit the bill.
Old 28-02-11, 10:24 PM   #9
muzikill
muzikill's Avatar
A few tricks;
ive got a tub of Castrol LM kicking about.............
Old 28-02-11, 10:25 PM   #10
Yeah that's ok for most stuff. complex is better.
Wish List... fenjer SV Ecosse 18 12-11-10 10:35 PM
Spannerman equivalent Macc/Buxton area? boot SV Talk, Tuning & Tweaking 23 08-03-10 02:17 PM
NGK CR7E or equivalent Holdup SV Talk, Tuning & Tweaking 6 11-03-09 12:24 AM
Brake fluids .... More useless information Spokey SV Talk, Tuning & Tweaking 21 03-11-08 09:36 AM
Skype do you have it or an equivalent? Stig Idle Banter 13 04-02-08 11:45 AM
