Old 13-02-11, 08:48 AM   #1
steveg
steveg's Avatar
Default Ignition barrel question.
Hi
After having my sprint's ignition screwdrivered , the little plastic flap which protects the barrel has been broken off
Now open to the elements , will I have to keep covered with something to stop water getting into switch or should it be ok
Believe electric connections are under barrel ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 13-02-11, 09:57 AM   #2
rictus01
rictus01's Avatar
Default Re: ignition barrel q
the actual switch is normally barriered from the mechanical lock barrel, so from that perspective it' should be fine, however it is now open to all sorts of muck getting in there, so be sure to give it a bit a wd40 every so often, try not to put grease in there as it just acts as something for grit to stick to.
Cheers Mark.
Old 13-02-11, 09:59 AM   #3
steveg
steveg's Avatar
Brill
Thanks Mark
AKA Papa Smurf
Curvey Ignition Barrel + Key Typhoon For Sale - SV's and SV related items 3 13-06-10 06:54 PM
Ignition Barrel Sticking svdemon SV Talk, Tuning & Tweaking 4 31-03-09 05:32 PM
Ignition Barrel Help! krhall Bikes - Talk & Issues 7 19-02-07 11:13 PM
Ignition Barrel BILLY SV Talk, Tuning & Tweaking 12 24-08-06 09:02 PM
Ignition barrel for a K2 Mervin Stuff Wanted 0 03-01-06 04:29 PM
