Old 21-02-11, 08:06 PM   #1
muzikill
muzikill's Avatar
Default Gearbox buying advice for K3 needed
My K3 was registered in the uk november 03. I have been told that only k3 and older gearboxes would fit it, is this right coz there a few newer ones!
Theres a few on ebay on the following link, some buying advice would be appreciated!
There are some on it that say would suit 03,04,05 etc that can't be right can it?
http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
Old 21-02-11, 08:28 PM   #2
barwel1992
Default Re: Gearbox buying advice for K3 needed
i think some parts will fit others wont like i think its the selector barrel that dosn't fit but not 100%
LINK
Old 21-02-11, 08:43 PM   #3
zadar
99-03 are same. 04 and up are different.
Difference is in drive shaft only. 04 and newer shaft is little longer and uses extra washer and o-ring on end. All other parts are same.
Old 21-02-11, 09:11 PM   #4
muzikill
muzikill's Avatar
I thought so, so buying anything 04 upwards aint gonna work eh?
thanks for the advice again zadar! - im going round in circles trying to get the right parts. What you guys think about the ebay ones?
Will it be ok to use the barrel & forks i still have?
http://forums.sv650.org/showthread.php?t=162680&page=2
This page shows the forks tbh there's hardly a scratch on em!
Old 22-02-11, 12:23 PM   #5
muzikill
muzikill's Avatar
Ive been rallying round trying to get hold of a good part at a good price and a few have asked for the driveshaft length for a k3 just in case they send the wrong one. Does anyone know what the size is? - i wont be back up to the garage where the bike is until the weekend to check myself.
Old 22-02-11, 07:15 PM   #6
zadar
216mm.
Old 22-02-11, 09:05 PM   #7
muzikill
muzikill's Avatar
Zadar these are the measurements on mine..... i went up tonight to check (changed the spark plugs and the air filter on the cage whilst i was up there!)
Driveshaft (the shaft that has the selector drum, 2 selector forks) the shaft the connects to the chain that drives the back wheel
200mm
Transmission (the takes the power from the crank through the clutch)
215mm
These differ from yours!
Old 22-02-11, 09:46 PM   #8
zadar
Driveshafts is same on all, 200mm.
Countershaft 99-03 is 215.8mm and 04-up is 217.5mm.
Little under 2mm difference.
Old 22-02-11, 10:15 PM   #9
muzikill
muzikill's Avatar
ta zadar, sorted for specs for some calls tomorrow - 2mm diff! - wtf, why did they bother changing it eh?
Old 22-02-11, 10:31 PM   #10
zadar
Change is cases.
K3 Gearbox buying advice wanted muzikill SV Talk, Tuning & Tweaking 0 11-10-10 06:51 PM
Advice on buying an SV please? BUTTYBIKER Bikes - Talk & Issues 11 14-11-08 10:17 PM
buying advice (which one) hovis Bikes - Talk & Issues 25 13-02-08 10:04 PM
Buying K7 quick advice needed!! KnightRider SV Talk, Tuning & Tweaking 1 15-06-07 07:08 PM
Buying advice needed pegasus Bikes - Talk & Issues 10 29-07-06 10:57 AM
