Old 15-03-11, 06:24 PM   #1
Nicky S
Nicky S's Avatar
Default A question to the orgs panle beaters and sprayers
hey
iv been working on my bellypan sanding it down filling it with p38 and sanding it down some more. over and over again. i have also used wet and dry sand paper on it. im now very happy with how it is and would like to primer it and then paint it.
but iv got some questions and would like advice from people that do it every day.
dose the primer have to be a special kind as i normale just use a grey primer.
what sort of paint am i looking at, as i know the paint code is YD8. but is it a Metallic or Pearlescent Paint. also is there any diffrence in how you mix the paint.
at work i spray forklift trucks. ok no car room finish but they look smart no runs and not patchy. but all i do to that paint is thin it down with thiners mix it then away i go spraying. wait for it to dry, job done.
but is that all i have to do to the paint for my bike as i did ask a mate and he said you have to add K2 harderner as well as thiners but then my mate at work said you are not aloud to do this anymore.
also once the paint has dryed do i need to then spray it with clear lacquer or will the finish come from the paint.
any help or advice you can give will be great
nicky s
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 15-03-11, 06:32 PM   #2
timwilky
timwilky's Avatar
Default Re: A question to the orgs panle beaters and sprayers
If you are using a 2k paint, yes you will need to add hardner as well as thinners. Of course you can DIY, but it is not advised if you do not have an air fed mask as it tends to be very nasty.
Personally if you do not know what has been on the panels before, spray an isolator, use plastic primer. And add a flex additive to the paint for the plastics
Not Grumpy, opinionated.
Old 15-03-11, 06:50 PM   #3
Nicky S
Nicky S's Avatar
ummm i think i will leave the hardner. as i dont have a air feed marsk
well it was sparyed by a mate of mine 2 years ago and he just primered it sprayed it then lacquered it.
flex additive ????? do i still add thiners as well ?
Old 15-03-11, 06:55 PM   #4
Nicky S
Nicky S's Avatar
when you say this do you mean just thin the paint down with thiners. spray it then spray lacquer ????
Old 15-03-11, 07:34 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
Originally Posted by Nicky S View Post
flex additive ?????
stops teh paint cracking and flaking when the panels move, you will need it for bikes as they flex a lot, especially if the belly pan is fibreglass, it will flex alot with the wind
05 DRZ400E
RIP hovis
The orgs newest recruit! paiste Photos 23 27-10-10 12:12 PM
Paint sprayers in East Anglia... kellyjo East Anglian Revolution 2 13-07-10 04:13 PM
Good cheap sprayers? wahwah Guildford Massive 11 14-06-10 05:01 PM
Local sprayers??? neilhatch Thames Valley 4 06-07-09 09:16 AM
Anyone know any bike (wheel) sprayers in Dorset? sv_rider1990 South & West Surfers 0 11-03-08 06:14 PM
