Old 15-03-11, 09:31 PM   #1
davepreston
Default check, no start, meta alarm, cant dealer mode
ffs ive had the bike 3 mins and its fecking me off
ok red light on below the neutral light
"check" below mileage
oil pic in corner on
cant put into dealer mode (engine off, cross two top side by side points with wire, still goes straght to normal mode , no ch or blank dash
meta alarm going off 30 secs after arming, but seems to disarm ok (it turns of the sirens)
HELP oh mighty org
Old 15-03-11, 10:09 PM   #2
davepreston
Default Re: check, no start, meta alarm, cant dealer mode
also should say its trying to kick over fine but just not kicking in
Old 15-03-11, 11:23 PM   #3
cluffy
I went out ont bike other day.. wouldnt start and said check below mileage, thought my optimate had blown fuse, tried bumping it to no avail.. it tried turning over on bump but as i put the ignition on it didnt make the whirring noise from the throttle bodies, turns out id knocked the emergency cut off switch.. i know thats the simplest thing to check but because its so simple it jogged my memory.. ?
Danny
Old 16-03-11, 12:25 AM   #4
davepreston
tried numerous times
Old 16-03-11, 12:36 AM   #5
cluffy
sorry then buddy but i wouldnt have the faintest.. im sure its only a mater of hours before somone comments with useful info. I was only saying as i was p1ssed off with mine not starting and it said 'check' under the speedo and i didnt know what it meant.. pah
Old 16-03-11, 12:43 AM   #6
davepreston
hopeing its something simple like the gear safety switch, its not the clutch ones, as for the alarm i just dont have a fecking clue where to start
Old 16-03-11, 01:01 AM   #7
Webber
Chec on mine normally means i've used the cut off switch, maybe a problem with that lose connection maybe? If not check the manual and see what it says in regards to 'Chec'
Old 16-03-11, 02:07 AM   #8
monkey
Just a point in case it's valid. The meta alarm (I assume it's a 351) passively immobilises only. You can switch on the ignition but it won't fire/turnover (depends how it's wired). Does the alarm sound for 30 seconds after you switch the ignition on?
Old 16-03-11, 06:43 AM   #9
davepreston
its a meta v2 monkey mate and i shall test that when i get home at 8am
Old 16-03-11, 07:57 AM   #10
davepreston
no left on for over a minute no alarm
this is a bike which just had an accident, so could it possibly be something that was damaged what should i be checking in particular, this check message is pi55ing me right off
Meta alarm Icanopit Bikes - Talk & Issues 6 10-11-09 11:29 PM
How do you put the bike in dealer fault mode? rowdy SV Talk, Tuning & Tweaking 7 31-01-09 09:07 AM
META Alarm....HELP with immobiliser! thepyrofish SV Talk, Tuning & Tweaking 12 01-04-06 06:54 PM
Meta Alarm Help!!! Samurai Bikes - Talk & Issues 5 09-02-06 02:52 PM
meta alarm pagers Dimax3 SV Talk, Tuning & Tweaking 6 04-01-70 07:20 PM
