Old 18-03-11, 12:09 PM   #1
Ceri JC
Default Source for 100% legal metal reg plates?
I'm looking for a UK supplier of small, legal number plates. I want it pressed from a single sheet of metal, as it'll be used offroad. I would also like it to have the EU GB marking displayed on it, rather than adding another sticker.
Legally required* minimum sizes for motorcycles are as follows:
Characters Size
Height 64mm
Width 44mm
Stroke 10mm
Side margin 10mm
Top & bottom margin 10mm
Space between characters 10mm
Space between groups 30mm
Within reason, cost is not an issue. Can anyone recommend somewhere that might be able to help?
*No, these aren't hearsay and the oft-quoted 9'x5' is nonsense, I have an authoritative source that confirms this.
Old 18-03-11, 12:39 PM   #2
davepreston
Default Re: Source for 100% legal metal reg plates?
id give some clasic bike places a ring, sure all the old bikes had metal numberplates so they must have a source for them
hth
Old 18-03-11, 12:43 PM   #3
Dicky Ticker
Local Travellers Site may have some but the numbers may not be what you want
Old 18-03-11, 12:47 PM   #4
Dicky Ticker
As new numer plates have to conform to different reflective standards and unless you are fitting it to a classic vehicle it may be difficult to source as suppliers now have to keep a record.
Old 18-03-11, 01:02 PM   #5
jonny.boyd
jonny.boyd's Avatar
As Dicky Ticker said above - that document states that numberplates must be made of self reflecting material. Not sure how easy this would be to do to a metal numberplate (may just need a special base paint or something??) But something to bear in mind..
A quick google search found this site:
http://www.4plates.co.uk/metalplates.asp
cost £40 - may be worth a call to check legality of their plates..
HTH
jonny.boyd is offline   Reply With Quote
Old 18-03-11, 01:45 PM   #6
Dicky Ticker
My bike registration is from one of my old trucks which originally had a metal plate but I had to change it when fitting it to the bike to conform with the change in law regarding the reflectivity[?] of the background.
Old 18-03-11, 03:23 PM   #7
Ceri JC
I've found places that are listed as legit sellers selling metal plates (it seems the paint they use determines whether or not it meets the reflective requirements). I've found somewhere that fits the bill for metal, reflective, legal, but not EU GB marking.
Old 18-03-11, 03:41 PM   #8
Berlin
The one and only...
http://www.jepsonandco.com/blackands...mberplates.htm
Old 18-03-11, 10:06 PM   #9
Shaun.
http://www.bike-plate.com/motorcycle-plate/sizes.php
There ya go mate
Old 18-03-11, 10:23 PM   #10
cbay
cbay's Avatar
I'm a Registered Number Plate supplier and I believe that the metal pressed plates can only be used on a certain aged car/motorbike.
If you get pulled you will get more than the usual £60 fine. (Plus it will be obvious, flashy modern motorbike with classic metal plate on it.)
Shorter Number Plates - Legal? and where from? krhall Bikes - Talk & Issues 8 08-09-09 12:41 PM
clutch plates fricton and metal ones sv650nutter149 For Sale - SV's and SV related items 0 11-02-09 10:47 PM
Legal Number Plates - Where From? krhall Bikes - Talk & Issues 11 03-07-08 05:16 PM
curvy rear brake lever & indicator metal plates Paws Stuff Wanted 3 26-01-08 11:10 PM
Legal Number Plates pingu SV Talk, Tuning & Tweaking 9 21-11-05 10:43 AM
