Old 18-04-11, 05:02 PM   #1
Nobbylad
Nobbylad's Avatar
Default Tyre wear opinions please.
OK..so I know I need new rubber, however this set of Avon Storm Ultras have done around 6-8k and I wanted opinions on the wear on the front. I appreciate the rear has a harder compound in the middle which helps prevent it squaring off as quick, however the front has worn a lot more and almost appears to be worn slightly unevenly, with seemingly more wear on the RHS (as you sit on the bike).
The tyres were new when I did the Gixer front and rear suspension mods.
Thoughts please?
Old 18-04-11, 05:12 PM   #2
Default Re: Tyre wear opinions please...
Think the wear you are reffering to has something to do with the camber of the road. Of course I could be talking out of my ****.
My car tyres did something similar
Old 18-04-11, 08:45 PM   #3
Stonesie
The camber could contribute, but not as much as roundabouts...
Old 18-04-11, 08:48 PM   #4
husky03
you need to lean over more
Old 18-04-11, 08:53 PM   #5
yeah, the Avon '1000 mile' or 'minimum tread'marker for their free tyre guarantee is still on it!
Old 18-04-11, 09:42 PM   #6
Nobbylad
Nobbylad's Avatar
Huh?! There's only so far you can lean over when travelling in a straight line up and down the same M-way every day! lol
Seriously though, I always buy the tyres in pairs, the last pair were standard Avon Storms without the dual compound rear, on a completely stock suspension set up. The rear was well squared off and the front was nowhere near as bad as the one above.
This set were put on when I did the suspension mods and I was just wondering if the harder compound on the rear has meant it has lasted a lot longer than the previous and therefore the front is noticeably worse, or whether the suspension changes may have affected the wear on the front i.e. loading it more (or maybe just encouraging me to brake harder)?
Old 18-04-11, 09:46 PM   #7
I was led to believe the original Storms and even the Azaros were a dual compound tyre.
I may also be talkin swollox
tyre wear fadedhalo SV Talk, Tuning & Tweaking 3 14-04-09 04:17 PM
tyre wear? hovis Bikes - Talk & Issues 16 05-07-07 02:11 PM
tyre wear xrphil Bikes - Talk & Issues 6 06-10-06 10:25 PM
what could this tyre wear mean? Warren SV Talk, Tuning & Tweaking 26 27-09-06 09:55 PM
Tyre Wear TheMickster Tyres 2 07-06-06 10:48 AM
