Old 23-04-11, 02:40 PM   #1
danf1234
Default Scotoiler Dispenser Nib
I was just checking the bike over for Shropshire and I noticed my scotoiler dispensing nib was missing. It must have been ripped off by the chain.
Question I have is has anyone had any experience of using other materials. I am thinking of using microbore copper pipe instead of the black plastic.
Anyone tried?
Old 23-04-11, 02:54 PM   #2
warmshed
Default Re: Scotoiler Dispenser Nib
What size hole is in the nib? I could turn one up in brass if you want one. Once we know the bore size just let me know what bore pipe it has to go in. No charge. Dave
Old 23-04-11, 03:00 PM   #3
danf1234
Very kind I will see what I can find out!
Old 23-04-11, 03:01 PM   #4
Some model shops sell small brass pipe, couple of mm in diameter. I use it on all scotoiler installs these days.
Old 23-04-11, 03:01 PM   #5
What happens when the metal pipe gets munched? I'd stick with plastic just in case
Old 23-04-11, 03:04 PM   #6
You fit it right so it doesn't get munched, being rather rigid compared to some piddly bit of biro tube it stays put.
Old 23-04-11, 03:07 PM   #7
danf1234
Luckily I have a micrometer in the Garage!
Outer bore is 3.15mm
Inner bore (hole size) is 1.65 mm
Old 23-04-11, 03:11 PM   #8
danf1234
Chris,
what is the right way to do it using copper pipe?
Old 23-04-11, 03:21 PM   #9
Use one of the little clamp things in kit onto paddock stand bobbin or spindle to aim the pipe at the rear sprocket (or even rubbing on it a bit)
Old 23-04-11, 03:28 PM   #10
danf1234
Exactly how I have it set up now, but with plastic pipe. So hopefully the copper pipe is a straight swap
Scottoiler Dispenser Nib Position Sruffy SV Talk, Tuning & Tweaking 36 30-06-10 02:47 PM
Scottoiler Dispenser Nib jamesterror Bikes - Talk & Issues 15 09-07-09 03:43 PM
scotoiler help please DaveP SV Talk, Tuning & Tweaking 4 25-05-09 10:31 AM
Scottoiler: Dispenser Assembly & Injector. Akula Idle Banter 2 06-05-06 08:23 AM
scotoiler russg SV Talk, Tuning & Tweaking 12 11-03-06 11:37 PM
