Old 25-04-11, 03:15 PM   #1
all the gear
Default SV650 K4 thrown rod - which other year engines fit?
Hello all, firstly I’m new to the SV650, and would appreciate some advice .I have an SV k4 model with a thrown con rod low mileage 14k and full history .I would be interested to know if this is common and why?, engine number p507- 134195 it’s injection as you probably all know .I would like to know which engines are interchangeable with this bike. I have seen a low mileage v/strom one for sale but don’t really know if it will fit without any power loss/modification
ie is the power output from mapping or valves and cams? .Naturally if anyone has one let me know .thanks
Old 25-04-11, 03:31 PM   #2
markmoto
Default Re: SV650 thrown rod
as far as i know any injected motor will fit so long as its not one of the later twin plug motors...
Old 25-04-11, 03:45 PM   #3
keith_d
keith_d's Avatar
In normal use the SV engine is pretty darn reliable.
The most likely reason for con-rod failure is oil starvation resulting in high rates of bearing wear. This can occur for several reasons:
a) Poor maintenance
b) Wheelies
c) Oil pump failure
There is a chance that someone might have over-revved the engine by changing down at high speed, but usually that's accompanied by wrecked plastics where it's chucked them off.
Hopefully one of the real experts will be along to comment on which engines will fit your frame/ecu.
Keith.
Old 25-04-11, 03:50 PM   #4
barwel1992
^ cant really over rev an sv as they have a limiter, i know iv hit mine loads lol
mine been fine even with an out of balance crank and i wont lie gets ragged to the moon and back
Old 25-04-11, 05:09 PM   #5
markmoto
You can if you change down to many gears and let the clutch out with the road speed to high, the rev limiter only works when accelerating not when decelerating.
Old 25-04-11, 06:55 PM   #6
all the gear
thanks for your help ,I now know the one I had in mind won't fit so still looking
Old 25-04-11, 07:21 PM   #7
Some K3/4s were prone to throwing rods, dunno why.
Old 25-04-11, 10:21 PM   #8
wasn't the K3/4 that had a faulty batch of un rev limited ECU's?
Old 25-04-11, 10:23 PM   #9
Default Re: SV650 K4 thrown rod - which other year engines fit?
Could well be, also the first of a new conrod design.
Old 25-04-11, 10:26 PM   #10
very true. Happens with most motors and bikes (things go wrong)
What year SV650/ 650 s should I get? Naish For Sale - SV's and SV related items 8 23-08-10 08:56 PM
SV650 99-02 Engines for sale - Suitable for rebuild Ter For Sale - SV's and SV related items 17 14-07-09 10:18 AM
Looking for my 1st SV650, any year!! walera Stuff Wanted 0 20-04-09 02:04 PM
Who Should Have The Book Thrown At Him/Her 21QUEST Bikes - Talk & Issues 6 15-07-08 09:11 AM
Coffee Anyone?(thrown from van) scorpion Bikes - Talk & Issues 8 09-03-07 01:38 PM
