Old 25-04-11, 05:42 PM   #1
suzuki madboy
Default Valve clearances
Ok so i checked the valve clearances and this is what i got
Front cylinder
EX/R - 0.009
EX/L - 0.010
IN/R - 0.006
IN/L - 0.005
Rear cylinder
EX/R - 0.008
EX/L - 0.008
IN/R - 0.005
IN/L - 0.004
Old 25-04-11, 06:42 PM   #2
Stonesie
Default Re: Valve clearances
Another servece manual Coppy/Paste
The tappet clearance specification is different for intake and
exhaust valves .
Tappet clearance must be checked and adjusted, 1) at the time
of periodic inspection, 2) when the valve mechanism is serviced,
and 3) when the camshafts are disturbed by removing them for
servicing .
Tappet clearance (when cold):
IN . : 0.10 - 0.20 mm (0 .004 - 0.008 in)
EX. : 0.20 - 0.30 mm (0 .008 - 0 .012 in)
You are right on the lower limit with a few of them there assuming you are using Imperial measurements... Edited because I mis-read them as metric and typed a whole load of twaddle about measuring up for new shims.
NOTE, I am using the specs for a Pointy here as it is what I have.
Old 25-04-11, 06:45 PM   #3
TamSV
TamSV's Avatar
I was a bit confused there until I worked out you've used an imperial feeler gauge.
On the new fangled metric system the clearance spec is 0.1 to 0.2 mm IN and 0.2 to 0.3mm EX.
If my conversion is correct, yours look to be in spec.
EDIT: Just read Stonesie's post. Assuming the measurements are imperial (which they surely must be) then they're all within spec.
Old 25-04-11, 06:56 PM   #4
muzikill
muzikill's Avatar
btw, well done for taking the leap in doing this yourself!
Old 25-04-11, 07:36 PM   #5
suzuki madboy
cheers for the info guys... and sorry for the confussion witht he whole metric and imperial measurements!
But its all good now.
Im doing an oil and filter change tomorrow for the ride down to guernesy with the maud on the back on wednesday and with all the paniers tank bag ruck sack ect... what a hike thats going to be! staying in poole for the night then to weymouth for a ferry at 8am.
going to a wedding on the day of the royal wedding lol.
Valve Clearances stratman_001 SV Talk, Tuning & Tweaking 2 09-03-10 01:13 PM
Valve Clearances again! madness SV Talk, Tuning & Tweaking 25 28-01-10 09:42 PM
Valve clearances Spoon SV Talk, Tuning & Tweaking 17 08-08-09 11:49 AM
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve clearances yorkie_chris SV Talk, Tuning & Tweaking 41 28-09-07 06:46 AM
