Old 19-05-11, 04:29 PM   #1
chamiakmako
Question Tubular handlebar conversion for Pointy 'S'?
Hi guys,
anybody over here done a handlebar conversion on pointy SV650 S K8?
Do I need for this conversion new grips and bar end weights?
(my bike is almost brand new so the grips and bar end weights are like new …)
Many Thanks for your help
Old 19-05-11, 05:15 PM   #2
toxic
Default Re: handlebar conversion ???
You can re-use the grips, throttle side is a given anyway. I think naked bar ends are different from ugly plastic bike ones.
Old 19-05-11, 10:20 PM   #3
chamiakmako
Hi Toxic,
Thanks for your reply - but I forgot to mention I am about to convert from clip ons to regular handlebars ...
Many Thanks
Old 19-05-11, 11:14 PM   #4
stormingjoe
stormingjoe's Avatar
Default Re: Tubular handlebar conversion for Pointy 'S'?
I got some risers of evilbay, http://cgi.ebay.co.uk/2-Bar-Riser-7-...item27bb052919, drilled and fitted to top yoke, fitted some renthals with the cross brace, re-routed cables to fit, best to take tank off and drop radiator and take lower fairing off. Clutch cable routed threw side of frame, took electric bits off carrier under airbox and routed throttle cables as required.
stormingjoe is offline   Reply With Quote
Old 19-05-11, 11:39 PM   #5
Supervox
No more Mr Nice Guy
Supervox's Avatar
The top yoke on the 'S' is NOT designed to be load bearing like the one on the Naked bike - a better solution is to spend the money and replace the top yoke with one designed for the job.
Never argue with an idiot - he'll drag you down to his level and then beat you with experience
Supervox is offline   Reply With Quote
Old 20-05-11, 12:04 AM   #6
stormingjoe
Time will tell, seems strong enough (my opinion only), not had problem yet, 2000 miles done already! Load should not be an issue as sitting more upright rather than on top off and over front end.
Old 20-05-11, 08:26 AM   #7
Supervox
No more Mr Nice Guy
Supervox's Avatar
The loading comes from the fact that you are using the top yoke to steer the bike as opposed to the forks.
handlebar conversion chamiakmako For Sale - SV's and SV related items 0 19-05-11 03:54 PM
ABM comfort Handlebar Conversion Kit for Pointy SV650S nomad For Sale - SV's and SV related items 3 07-02-09 01:26 PM
Handlebar conversion SAMMY650 SV Talk, Tuning & Tweaking 21 08-03-08 03:14 PM
Bandit handlebar conversion Warthog SV Talk, Tuning & Tweaking 0 05-06-07 09:13 AM
FS: Good as new Handlebar conversion kit for pointy **SOLD** Knaapie For Sale - SV's and SV related items 7 04-06-06 10:02 PM
