Old 23-05-11, 07:28 PM   #1
prilpot
Default forks still using all travel
04 sv 650
ohlins 9.5 springs
emulaters
maxxion rods
15 w oil
preload only 2 rings showing
bike still uses all travel on the brakes cable ties round legs are hitting the underneath of bottom yoke
i am about 14 stone in all my kit
any one got any advice on how to stop this
Old 23-05-11, 07:30 PM   #2
martin15s
Default Re: forks still using all travel
correct oil level??
Old 23-05-11, 07:32 PM   #3
prilpot
110mm air gap
Old 23-05-11, 09:47 PM   #4
rictus01
rictus01's Avatar
have you setup/checked the riders sag? but if travel is that far I'd suggest the spacers are to short, so it's worth checking that to.
Cheers Mark.
Old 24-05-11, 12:17 PM   #5
mikerj
Using all the travel is a good thing - you don't want to make it so stiff that it only uses a small part of the travel. Most likely it's only getting to the end of the travel if you hit a bump under under hard braking, mine is exactly the same (0.95 springs+emulators).
Old 24-05-11, 12:51 PM   #6
flymo
flymo's Avatar
Originally Posted by mikerj View Post
Using all the travel is a good thing.....
Not when the cable ties are bottoming on the yoke its not.
Are the forks set at the standard position in the yokes or have you dropped the yokes further down?
Old 24-05-11, 12:53 PM   #7
flymo
flymo's Avatar
...one other thought... are the springs the same length as those they replaced? You may need to make some longer spacers. Have you set the front preload up properly using a tape measure rather than just number of rings showing on the adjuster?
Old 24-05-11, 12:56 PM   #8
flymo
flymo's Avatar
Cheers Mark.
sorry, just noticed this post.
.... +1 but including both static and rider sag.
USD GSXR1000 k1 forks | standed forks - curvy Nicky S SV Talk, Tuning & Tweaking 113 07-09-09 01:12 PM
AR travel up. phil24_7 South & West Surfers 18 12-06-08 09:42 AM
Travel Insurance. To buy or not to buy? lol Bikes - Talk & Issues 10 29-12-07 08:53 PM
O2 Arena travel Gordon B Idle Banter 1 17-06-07 09:19 AM
A new way to travel! thedonal Idle Banter 1 08-06-07 04:47 PM
