Old 24-05-11, 06:55 PM   #1
Daveo2010
Default 'Tour Max' reg/rec
Hi all, my R/R is labelled "Tour Max" - is that OE, or has some previous owner already sorted it?
Cheers,
Dave.
Old 24-05-11, 08:10 PM   #2
Default Re: 'Tour Max' reg/rec
Not OE
Old 24-05-11, 09:00 PM   #3
Daveo2010
Sweet - one less thing to worry about I guess Thanks
Old 24-05-11, 09:07 PM   #4
Nothing is bulletproof. Cheap chinese aftermarket may be worse than stock.
Old 24-05-11, 09:10 PM   #5
Daveo2010
I guess you're right. It must have been done for a reason I suppose. I'll pop a multimeter on there anyway, see what's what
Ta,
D
Old 26-05-11, 11:17 AM   #6
Daveo2010
My cheapo multimeter doesn't seem to have an Ammeter (unless I'm just missing it!), anyway, voltages are:
DC at the battery:
- Lights off:
- - 1500RPM = 13.8v
- - 5000RPM = 13.6v
- Main bean:
- - 1500RPM = 13.4v
- - 5000RPM = 12.6v *
Unregulated no load AC = 80v @ 5000RPM (Haynes says '60v +')
* Haynes says to check with main beam on at 5000RPM and the spec range is 13.5-15.5v so I'm a bit low but is it a problem? I have no particular electrical problems that I know of, though she sucks down several hours of juice from the optimate once every few weeks. During the winter I was a little concerned about a bad smell when using the heated jacket and gloves, but I guess it was something else (the jacket bedding in, ACF50 burning off or something) that was making the stink, cos the wiring around the reg/rec all looks good.
Cheers,
D
Old 26-05-11, 11:51 AM   #7
Dave20046
Dave20046's Avatar
Tourmax are good aftermarket if its any piece of mind,was dubious when I fitted mine but asked around a bit
Old 26-05-11, 09:22 PM   #8
Daveo2010
Sweet, I think I'm gonna assume I'm fine unless I get any actual signs of a problem, it's not mega mega low after all.
Old 26-05-11, 09:35 PM   #9
Holdup
Originally Posted by Daveo2010 View Post
DC at the battery:
- Lights off:
- - 1500RPM = 13.8v
- - 5000RPM = 13.6v
- Main bean:
- - 1500RPM = 13.4v
Im no expert and im still learning but i would say that you have a problem there and its undercharging, voltage dropping down as the bikes revved up.
I would be happily corrected though
Old 27-05-11, 01:41 AM   #10
Something is wrong.
Check for orrible connectors, if none then reg rec is no good
Nearly end of tour Richie Pennine Massive 19 01-11-08 01:36 PM
Le Tour(Tour de France 2008) Pedrosa Idle Banter 51 23-07-08 09:49 AM
SV on tour charris Photos 11 02-07-07 08:43 PM
On tour Gazza77 SV Ecosse 9 13-04-07 11:45 PM
3 Day Tour Kilted Ginger SV Ecosse 4 31-08-06 09:07 AM
