Old 12-06-11, 08:37 PM   #1
muzikill
muzikill's Avatar
Default Fitted new exhaust gasket - smoked/gone
The rear exhaust pipe was smoking even at full temp and even though the clamp was tightened, this was because i didnt replace the gasket.
So today i replaced it, after a while it still smoked at the clamp area then as the heat built up it disappeared. Does this sound normal? - i was thinking that this is how the gasket 'seals' itself.
Sk6 Exhaust gasket mackrilld SV Talk, Tuning & Tweaking 1 10-04-11 09:36 AM
Exhaust (Muffler) gasket/connector Blue_SV650S Stuff Wanted 2 18-09-06 12:02 PM
Exhaust Gasket and Studs TSM SV Talk, Tuning & Tweaking 2 07-09-06 06:22 PM
Fuel exhaust fitted Rog Photos 13 25-04-06 03:05 PM
Exhaust Gasket Sizes? andyaikido SV Talk, Tuning & Tweaking 3 14-02-06 05:47 PM
