Old 06-07-11, 10:11 AM   #1
Badeye
Default Bike Doesn't Feel Right?
Hi Guys,
About 6 weeks ago i had a low speed spill and ended up in a grass ditch (never a good thing). Anyway since then the bike seems to run ok but doesn't seem to get upto speed as quickly as it use to. The bike came down on the right hand side, theres a few scrapes on the clutch cover but no cracks and no oil leaking.
I distinctly remember i could get to 100mph with not alot of twist on the throttle but now i have to give it loads to even reach that speed. Any idea's? It's 2003 Pointy, could it just be a matter of the clutch just need readjusting? also the before the spill i adjusted the idle to 1300 and it would stay at that even when cold but now only goes to 1300 when warmed up.
My next service is at 8000 miles which i am 1000 miles away from, is there anything obvious i should check?
Thanks,
Si
Old 06-07-11, 10:18 AM   #2
dyzio
dyzio's Avatar
Default Re: Bike Doesn't Feel Right?
Is it running on both cylinders?
Old 06-07-11, 10:21 AM   #3
Badeye
yeah it appears to be.
Old 06-07-11, 12:08 PM   #4
Badeye
OK i just thought, when i had the spill and i rode my bike back home it was sound, HOWEVER will i was fixing it up i did mess a little with the clutch adjuster on the lever could this be causing what i think could be the clutch slightly slipping.
Should i try adjusting the clutch from the bottom or not?
Old 07-07-11, 07:29 AM   #5
Badeye
Had a dabble with the clutch after viewing some threads on here about adjustment and this morning the bike seems to be pulling as normal, so after all it appears to have been the clutch just needing adjusting. Thank god it wasn't anything serious.
PHEW
Si
Don't feel well. timwilky Idle Banter 23 14-02-10 05:24 AM
not been on your bike for a while? hows it feel? kwak zzr Bikes - Talk & Issues 52 29-01-10 12:05 PM
How do you feel about ya bike after an off Shellywoozle Idle Banter 33 22-07-09 10:58 AM
Should I feel bad about this ?? FG1 Idle Banter 15 22-09-07 03:34 PM
Feel like putting the bike away for the winter. stuartyboy SV Ecosse 10 17-06-07 11:10 PM
