Old 17-07-11, 07:52 PM   #1
callum
Default WANTED 2 finger front brake lever 2003 model
As title Im after a 2 finger front brake lever for a 2003 sv 650, what you got?
Old 17-07-11, 09:00 PM   #2
Teejayexc
Default Re: WANTED 2 finger front brake lever 2003 model
Aren't they all
Old 17-07-11, 09:24 PM   #3
Originally Posted by Teejayexc View Post
Aren't they all
+1
U mean a stubbie lever?
Old 17-07-11, 10:17 PM   #4
coolevilangel
ive got a black chinese pazzo imitation stubby lying about somewhere
Old 18-07-11, 07:10 AM   #5
callum
Yeah sorry thats what I meant a stubby lever, how much you want for the chinese one and is the build quality any good?
Old 18-07-11, 06:40 PM   #6
ravingdavis
The Chinese Pazzos are pretty good, I bought a set for my GSXR seem very good so far.
http://cgi.ebay.co.uk/Pro-Clutch-Bra...item4aac53d24d
Only caveat so far is that the brake lever was slightly to thick and needed the raised ridge sanding down a little, nothing a little wet&dry couldn't sort and now they are perfect.
Old 18-07-11, 08:01 PM   #7
Did you mention you had to move the lever back manually cos it didnt return on its own before sanding it down?
Old 18-07-11, 08:04 PM   #8
ravingdavis
That's pretty obvious Phil as I would not have sanded it down if it moved back properly... duh!
Old 18-07-11, 08:16 PM   #9
Red Herring
Red Herring's Avatar
A hacksaw blade?
Seriously, it's all I did. Cut to the length you want, then get the ball welded back on the end. Costs about £10.
Old 18-07-11, 08:49 PM   #10
Originally Posted by Red Herring View Post
A hacksaw blade?
Too posh to fall off are we
RH Footpeg Hanger, Rear Brake Lever and Clutch Lever for 2004 Naked Wanted Drumming_Animal Stuff Wanted 0 26-07-10 10:52 PM
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
Front brake (curvy model) Paws SV Talk, Tuning & Tweaking 10 01-09-06 09:22 AM
