Old 30-07-11, 09:05 PM   #1
metalhead19
Default SV front wheel
Am after a Pointy front wheel, if it has discs than fantastic, if not then no worries.
Old 30-07-11, 10:21 PM   #2
Chris Bird
Default Re: SV front wheel
I've got one. It's from my k6....
Do you need the spindle and the rest of the gubbins?
Old 31-07-11, 02:40 PM   #3
metalhead19
Yeh I will do. Basically I want everything to be able to put my tyre on it and shove it on the bike. (I have the axel bolt though)
Old 31-07-11, 08:11 PM   #4
Gaz.sv650
Gaz.sv650's Avatar
I have one its as new had it powder coated then did the gsxr swap also has a new pirelli done less than 400miles disc and spindle pm m if you are interested
Gaz.sv650 is offline   Reply With Quote
Removed Front Wheel, Front Break Lever Further Out KnightRider Bikes - Talk & Issues 4 24-01-11 07:47 PM
Injected Front Wheel Axle and Front Master Cyl Brkt adjblade Stuff Wanted 2 19-01-11 08:07 AM
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
