Old 01-08-11, 03:50 PM   #1
daveyrach
Post Rear caliper
Changed my rear pads yesterday and found the dust seals had perished and cracked and had been forced out by the pistons, i have a complete rebuild seal kit on order due tomorrow, i have a couple of questions.
1. How easy is it to split the caliper and changed the seals etc (I am mechanically competent)
2. I have an MOT on Saturday i take it it won't fail on that coz you can't see without taking the caliper off.
I want to do the work next week as i am not at work.
Thanks guys
Old 01-08-11, 05:35 PM   #2
mister c
mister c's Avatar
Default Re: Rear caliper
It is quite an easy job to split the caliper, only a couple of bolts. As for the MOT, as long as it isn't leaking oil & the braking force is alright, then I can't see you having a problem
Old 01-08-11, 06:13 PM   #3
daveyrach
Cool, brake is fine better than before in fact as they were almost down to the metal and squeeling like mad, not leaking checked that before i put the caliper back on, just running with no dust seals at the moment
Old 01-08-11, 06:44 PM   #4
TamSV
TamSV's Avatar
Todays Top Tip. Crack the tension off the joining bolts before you take the caliper off the hanger.
Old 01-08-11, 07:23 PM   #5
daveyrach
That had crossed my mind!
Old 01-08-11, 08:28 PM   #6
TamSV
TamSV's Avatar
Smart ass . Alright then. Top Tip No. 2...
Use the pressure of the brake system to pop the inboard piston. With the caliper disconnected you can remove the outboard piston by pushing it out from behind with a bit of rod through the banjo bolt hole.
One less potentially messy high-speed brake fluid ejection.
Old 02-08-11, 07:35 AM   #7
daveyrach
That really is a top tip, I will bear that in mind!
Old 02-08-11, 06:07 PM   #8
or my top tip.
Use a twin barrel footpump, a football adaptor and some decent tape as a gasket.
Got 2 inboard pistons out that way last year.
Not a bad take off for 40psi with a partially seized piston
Old 13-08-11, 07:02 PM   #9
daveyrach
Did this today, but could i crack the jointing bolts? Like hell could i, managed to change the seals without splitting it so only the tiny inner 'o' ring that was not changed, have to say though new seals make one hell of a difference, new fluid may have summit to do with it as well.
Rear caliper gfewster Stuff Wanted 1 19-03-10 07:37 PM
Rear Caliper SVDragRacer SV Talk, Tuning & Tweaking 4 08-03-09 10:56 PM
Rear Caliper... Grinch Stuff Wanted 5 02-07-08 10:06 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear Caliper Bikerz SV Talk, Tuning & Tweaking 15 08-03-07 09:18 AM
