Old 16-08-11, 09:37 PM   #1
dill89
Default Smokin' on 1 pipe
Okay so I've got an SV1000 SK3. Got it towards the end of June with nearly 19,000 miles on it. Now at the 20,500 miles.
My friend has told me that it has white smoke coming from ONLY the right exhaust, and ONLY when I accelerate reasonably hard.
Thought the bike smelled kind of sweet, like it was burning too much fuel, but had a sniff at the exhausts earlier and again it's ONLY the right exhaust.
I'm not mechanically minded so anyone who is know what my problem is?
Old 16-08-11, 10:24 PM   #2
mikerj
Default Re: Smokin' on 1 pipe
White smoke coupled with a sweet smell are typical symptoms of coolant getting into the combustion chamber.
Old 16-08-11, 10:33 PM   #3
Stonesie
Agreed, check the coolant level then try to follow the line of the right exhaust pipe to see if it has the most direct route to the front or rear cylinder.
Old 16-08-11, 10:45 PM   #4
dill89
Know what the fix is?
Does that mean head gasket is gone?
Old 16-08-11, 10:48 PM   #5
Stonesie
Hopefully the head gasket is goosed, it could be worse than that but lets cross that bridge IF we come to it.
Old 16-08-11, 11:08 PM   #6
dill89
ohhhhh no. I assume many hundreds for head gasket replacement and if it's not that then the engine is on it's way to imminent death?
Checked coolant level and it is just above "full", and the exhausts join together as one in the middle from what I could see, so it's a 2-1-2 set up>
Old 17-08-11, 07:22 AM   #7
warrenhewitt10
Which cylinders pipe looks like the path of least resistance as such... I think thats what they mean
Old 17-08-11, 07:59 AM   #8
Owenski
You sure you're friend didnt just take a leak down one of your pipes?
Old 17-08-11, 07:59 AM   #9
dill89
I would have to say rear cylinder in that case.
Old 17-08-11, 08:32 AM   #10
warrenhewitt10
I did, on the motorway, was quite the shot, quite proud of myself
Pipe Werx Exhaust Can and High level pipe DJ123 For Sale - SV's and SV related items 8 19-08-11 11:43 AM
Smokin' Aces rictus01 Idle Banter 7 18-12-07 06:36 PM
Smokin' Aces. Razor Idle Banter 46 29-01-07 12:35 PM
Smokin! timwilky Idle Banter 125 17-02-06 05:16 PM
