Old 17-08-11, 11:40 AM   #1
M65
Default Caliper Bleed Nipple
Dont flame me for this, but does the bleed nipple on the front caliper loosen by turning it clockwise or anti-clockwise? Im sure its clockwise but I dont want to force anything.
Old 17-08-11, 12:04 PM   #2
Owenski
Default Re: Caliper Bleed Nipple
Righty tighty, lefty loosie.
Never "tighten" it, just nip it up an 1/8th of a turn.
A recent bit of good advice given to me was to remove the nipple then apply a wrap of PTFE tape to the thread. It makes bleeding the brakes easier as no air gets sucked back in via the thread, for even more ease if you dont already have one - pop down to halfords and pick up a brake bleeding valve = perfectly bled brakes everytime First time!
Old 17-08-11, 12:23 PM   #3
_Stretchie_
Large Member
_Stretchie_'s Avatar
You shouldn't get grief over this mate, good on you for asking rather than snapping it off and having more problems. As Owenski said it is a normal thread so undo as normal,
How to amuze an idiot:
Look right-> <-Look Left
Old 17-08-11, 12:34 PM   #4
M65
Bugger. Mine is stuck well tight then!
Old 17-08-11, 12:35 PM   #5
Owenski
they're really brittle too so I wouldnt try forcing it.
Try heat etc first.
Old 17-08-11, 03:38 PM   #6
_Stretchie_
Large Member
What are you trying to undo it with?
Only asking as a six sided socket would be better than a spanner for example. I always start it off with a six sided socket, as they are not massively strong
Old 17-08-11, 04:02 PM   #7
+1. i always crack it open with a socket then close again then use a spanner.
Old 17-08-11, 04:17 PM   #8
M65
I tried opening it first with a spanner. It was that hard it managed to span the spanner! I better check I have a small enough socket
Old 18-08-11, 09:27 AM   #9
BoltonSte
Any idea on size?
I can check but most likely have one if you want to pop over one eve.
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 18-08-11, 11:11 AM   #10
_Stretchie_
Large Member
Usually 8mm
Rounded & Cheesed off bleed nipple - how the feck do you get them out and off? Paul the 6th Bikes - Talk & Issues 7 29-07-10 03:38 PM
Weeping rear brake bleed nipple. 5hort5 SV Talk, Tuning & Tweaking 8 02-03-10 08:27 PM
brake caliper bleed nipple size stuballs SV Talk, Tuning & Tweaking 6 02-12-08 05:28 PM
Bleed Nipple Size? pmapp SV Talk, Tuning & Tweaking 12 30-04-07 11:31 AM
How do I get a snapped bleed nipple out of a caliper? Cloggsy Bikes - Talk & Issues 19 19-01-06 10:20 PM
