Old 22-08-11, 12:00 PM   #1
LJH
Default Sprocket stamp has to be on outside?
I put on a new chain and sprockets and I have put them on so the stamp on the sprockets are facing inwards, I've been riding around like this for 100miles or so....but keep seeing that the print has to be facing outside....does it HAVE to be?
Old 22-08-11, 12:02 PM   #2
rictus01
rictus01's Avatar
Default Re: Sprocket stamp has to be on outside?
as a general rule, always check when changing if there is any off set on the old ones and replicate on the new, if there is none (if it's there it's usually the rear), then anyway you like is fine.
Cheers Mark.
Old 22-08-11, 12:13 PM   #3
LJH
Its just a renthal 14t front and standard back...so should be fine then.
Old 22-08-11, 12:14 PM   #4
rictus01
rictus01's Avatar
if that's the case, then yes should be.
Old 22-08-11, 12:29 PM   #5
if they are 'dished' then they will have an orientation to what side they go. the reason is to make sure that the chain has the correct offset to make it in line with each sprocket.
the fronts are usually flat both sides but the back's are usually dished. if the back is dished then the 'flat' side will go inwards.
520 Sprocket Christian525 Stuff Wanted 1 14-09-10 03:22 PM
Service History Dealer Stamp Page C9CRM Bikes - Talk & Issues 2 22-03-10 07:19 AM
14 T sprocket Quiff Wichard For Sale - SV's and SV related items 9 14-08-07 12:10 PM
Removing "NOT FOR ROAD USE" Stamp. TheStudent Exhausts 28 17-07-07 10:45 AM
7500 SERVICE/Book stamp big twin grin SV Talk, Tuning & Tweaking 3 14-03-06 07:58 PM
