Old 18-09-11, 07:38 PM   #1
Daveog
Daveog's Avatar
Default Blown curvy SV engine - K3> replacement possible?
Evening all,
Nearly ready to drop the engine out of my SV to discover how bad the problems are. Considering buying a replacement engine in the meantime.
I assume with K2 and before engines it would just be a straight swap, but I wondered if a K3 onwards unit would fit and would there be much more work involved in installing it (looms and things?).
Oh, and any suggestions where to buy engines, new or used?
Any advice would be gratefully received.
2002 SV650S K2 + 2005 CBR125-R (my 2009 SV650S Dark Grey K9 was stolen in Hextable 18/7/12 )
Daveog is offline   Reply With Quote
Old 18-09-11, 07:58 PM   #2
Default Re: Blown curvy SV engine - K3> replacement possible?
Fitting a injection engine from a Pointy into a Curvy. I think the general concensus is that if it was easy, everyone would be doing it?
Here's an engine, seem a bit pricy, but its from a curvy, so a straight swap for yours
http://www.ebay.co.uk/itm/SUVUKI-SV-...82230915243010
Old 18-09-11, 08:41 PM   #3
Daveog
Daveog's Avatar
makes sense, thanks maviczap.
Old 18-09-11, 08:53 PM   #4
To put pointy engine in curvy;
change inlet stubs, rotor, stator, block oil cooler and PAIR system.
Old 19-09-11, 06:27 AM   #5
m`baubz
if i may ask, why block the oil cooler?
Old 19-09-11, 08:58 AM   #6
You can keep it if you want but depends what exhaust you use, some will hit it.
Old 19-09-11, 09:04 PM   #7
Daveog
Daveog's Avatar
Engine out. Almost time for diagnosis.
Old 20-09-11, 07:25 AM   #8
muzikill
muzikill's Avatar
Im really interested in how this looks, pics please! - does the crank turn?
Blown up 400, what's needed to use 650 engine? frost2540 SV Talk, Tuning & Tweaking 7 05-10-10 12:02 AM
Value of a blown engine? 11,000 miles. Noble Ox Idle Banter 11 21-06-10 09:59 AM
Blown engine @ 120mph :( breakz187 SV Talk, Tuning & Tweaking 41 17-05-09 07:32 PM
'02 SV650 blown engine leonarpr For Sale - SV's and SV related items 4 11-01-09 12:35 AM
I've blown up yet another engine!! :( Blue_SV650S Idle Banter 9 14-09-08 04:58 PM
