Old 29-09-11, 02:22 PM   #1
matt_rehm_hext
Question Brake Caliper
Hi
Was taking my CG125's caliper off the mounts to have a look at the pads, long story short, lever got squeezed and the piston is obviously pushed out.
Is there a way of getting it back in without bleeding the fluid/replacing fluid?
Old 29-09-11, 03:09 PM   #2
Nicky S
Nicky S's Avatar
Is the piston out or just been moved a bit. If its just moved a bit just push it back. But make sure you take the lid off the brake fluid holder.
You should not need to bleed it. But bleeding ur brakes dose not take long.
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
brake caliper mouldy SV Talk, Tuning & Tweaking 7 24-03-09 04:37 PM
Brake Caliper Pin Gordon B Stuff Wanted 2 02-02-09 07:12 PM
Brake caliper help!! Wee-Man SV Talk, Tuning & Tweaking 4 03-06-07 07:49 PM
Brake caliper localhost Bikes - Talk & Issues 11 16-08-06 07:22 PM
