Took car to garage because clutch was slipping.
Garage said new clutch and slave cylinder required I said ok fine £275 later i received the car back and it would not go in reverse now. Took car back to garage and explained that it would go in reverse fine before clutch was changed and left the car with him. I then left the car with him and he replaced the clutch and slave cylinder for a 2nd time. The car at his point would still not go in reverse. At this point he said he could try a new master cylinder but this would be £137 extra. He replaced the master cylinder and this has solved the problem. I believe i am now going back to the garage to pay:- £275.00 for clutch and slave cylinder £137.00 for the master cylinder BUT the guy mentioned on the phone about the first clutch fitted was not faulty and put the point across to me to me about the issue of paying for the labor of replacing the clutch and slave cylinder twice. As it was the master cylinder at fault. mmmmmmmm............. What do you think? At no point did i instruct him to strip the gearbox out and replace the clutch and slave cylinder again. He did this off his own back without telling me. Gonna go to the garage tomorrow to pay and wanted to see what you guys think is fair. |
its not your fault they had to rip the clutch out again to fix a fault that should have been picked up on the first time, which sounds like they never tested the car after the repairs the first time.
#3 | |
Formerly Blue K5 with added bits Then Triumph Sprint ST with scottoiler and R&Gs & TOR exhaust Now Benelli Tornado |
I agree, tell them to do one, they should've diagnosed it correctly.
Fair enough if you have a new clutch and slave then pay for the 1st one but not for the labour on the 2nd. Why would they change the first one THEY fitted, didn't they fit it properly the first time??? Or use crap parts? |
Sorry to read of your problems, but your systems do not suggest a faulty master cylinder, more likely a failure to correctly realign the gear selector when the box was refitted. If the master cylinder had been at fault you would not have been able select any gear. Nor does a faulty slave cylinder lead to clutch slip, unless you are of course suffering a leak onto the clutch and topping up the reservoir.
Not Grumpy, opinionated. |
#6 | ||||
The clutch fluid was never required to be topped up. mmmm........... |
sorry but how can a master cylinder effect only reverse...
and if they try to give you grief about the second clutch ask to see the new old one he took out.. bet you a £5 its the same damn one! |
tell him to get bent!!!! politely
#9 |
Well as the clutch was slipping your going to have to stomp up that one . Most modern cars have a release bearing combined with the slave so its sensible to replace it. But I'd look at it then decide if its ok.
May have bled the clutch and then the master cylinder may have failed . Second clutch and labour ,no way ,miss diagnosed by the garage .
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#10 | |
If it went in with out engine running then It's clutch drag
What's the minimum size for a garage to be a garage? | the white rabbit | Idle Banter | 3 | 20-12-09 08:39 PM |
Work Question - concentricity of holes | Tris | Idle Banter | 5 | 26-03-09 08:33 PM |
Question regarding use of leisure battery to keep bike batteries going over winter in remote garage | monkey | Bikes - Talk & Issues | 13 | 22-09-08 06:14 PM |
Shift work legal type question... | Nick762 | Idle Banter | 8 | 02-07-08 10:00 PM |
Is my garage trying to rip me off?! | dmracing | SV Talk, Tuning & Tweaking | 9 | 30-04-07 08:31 AM |
