Old 16-10-11, 08:40 PM   #1
DJ123
DJ123's Avatar
Default Which chain type?
What type is the best type to get? I am a fair weather rider, avoid the wet riding if i can, and my bike has a scottoiler fitted. I'm after a good decent make that will last a long time and will be practically maintenance free.
X-ring, O-ring, HD and Standard options.
BMW F800ST
Old 17-10-11, 08:03 AM   #2
AndyBrad
Default Re: Which chain type?
tsubaki is the one to go for. Although ive not compared apples with apples the tsubaki chains ive had have appeared to be a lot smoother in operation than ek and did chains ive used in the past.
however there a bit more expensive and with a scottoiler and/or summer use i would happily use either of the above. bearing in mind the different grades btw. i wold go for an alpha tssubaki, vmx type did or srs ek all are not too bad on price.
Old 17-10-11, 09:10 AM   #3
O ring, X ring is not worth price premium. How many miles do you want? Do you have a scottoiler or are you likely to neglect it?
Rattle/Loose Chain type noise Dunn-y Bikes - Talk & Issues 1 29-09-11 10:17 PM
Which type of chain lube? mcgrimes SV Talk, Tuning & Tweaking 41 03-08-10 08:31 AM
Which type of chain and sprocket to get? iaincX04 SV Talk, Tuning & Tweaking 6 26-11-07 09:38 PM
Type of Oil heathsv650 SV Talk, Tuning & Tweaking 0 04-04-07 01:10 PM
Oil Type? ouchbadback SV Talk, Tuning & Tweaking 11 03-11-04 01:59 PM
