Old 19-10-11, 05:53 PM   #1
deejpj
Default How much Wynns Dry Fuel to use?
Hi,
As the temps are dropping off quickly now i want to be prepared and not suffer from carb icing on my regualr trip down the motorway.
I can get wynns dry fuel from halfords but all it says is use all of it in your fuel tank but that with cars in mind... Has anyone had any experience with this product and how much should i be using in my tank?
DJ
Old 19-10-11, 05:59 PM   #2
Default Re: How much Wynns Dry Fuel to use?
Pro FST is 100:1, so 100ml to 10l.
Old 19-10-11, 06:52 PM   #3
victor_meldrew
Not had my SV through a winter yet -- is carb icing a real problem with this bike (1999 curvy) ?
what kind of temperatures does it start to be an issue ? But there again I guess speed / wind chill will affect this ...
Is pro FST the best way to beat it ?
Old 19-10-11, 07:21 PM   #4
pro FST works but is expensive, so is premium fuel.
I've used isopropanol before, was looking at selling it by the pint on here but still checking it's not going to eat carby parts.
Old 19-10-11, 08:31 PM   #5
isopropyl alcohol should not eat anything rubber or plastic if used in dilution. benzene that is used as a valve lube in unleaded petrol is far more corrosive a substance. i use diluted isopropyl for cleaning records.
aren't most dry fuel stuffs just parrafin/kerrosene?
Old 20-10-11, 08:58 AM   #6
johnnyrod
johnnyrod's Avatar
I'm reasonably sure without looking it up that Wynns/FST is just IPA anyway. I've got a 1999 curvy and never had carb icing, ride it all year round.
Old 20-10-11, 03:53 PM   #7
daveyrach
I thought Curvy's had carb heaters, don't they use coolant to keep em warm, also can't see icing being an issue while on the move.
Old 20-10-11, 04:40 PM   #8
They have carb heat but it's useless electrical variety.
Some people have problems some don't. But it definitely can be an issue.
Old 20-10-11, 05:11 PM   #9
Teejayexc
Use this stuff, cheap as chips and just as effective;
http://www.medisupplies.co.uk/acatal...al_Spirit.html
Old 20-10-11, 10:23 PM   #10
Nope heavy oil doesn't help carb ice.
Also isopropanol.
Wynns petrol treatment garynortheast Bikes - Talk & Issues 12 13-04-11 04:57 PM
Fuel rant whinge moans hate fuel prices bah Daimo Idle Banter 54 18-02-11 11:02 PM
Wynns Brake & Clutch Cleaner Fluffer Hardware 3 18-01-11 09:59 PM
Where is the fuel? Lifted fuel tank. BoomBoomBox Bikes - Talk & Issues 72 07-12-10 01:01 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
