Old 05-11-11, 09:18 PM   #1
ibby33
ibby33's Avatar
Default Changing rear wheel bearings - easy?
hi,
how easy is it to change the rear wheel bearings, ive read the haynes manual and it seems simple but is it really that simple. As well do i replace them with standard ones or is there a upgrade for them??
Cheers David
ibby33 is offline   Reply With Quote
Old 05-11-11, 11:48 PM   #2
davegixer1300r
Default Re: Changing rear wheel bearings - easy?
it is simple just take care i would advise using a bearing supplier you will find them sooooo much cheaper than a bike dealer just take in the old bearing OR the Number off of the race and they will give you options but the OEM suppied Kyoto bearings £4 from my dealer.
Old 06-11-11, 06:25 AM   #3
ibby33
ibby33's Avatar
ok cool cheers for that. got a friend who services bike he said was going to be about £60 but i know what i'll do when i see him
Old 06-11-11, 10:25 AM   #4
davegixer1300r
here's the people i use
http://www.steelcitybearings.com/ind...earch&bcd=6203
just pop your number in and you get their stock level i find them very helpful.
Old 06-11-11, 11:59 AM   #5
£60 is a good price as it can be a mare of a job especially if you don't have the tools. you are paying him for his knowledge and use of his tools as tools cost money. it's not just a case of bashing old ones out and bashing new ones in. you have to know which side goes in first and the correct pressure or the spacer will push the centre bearing race out to much and wear the bearings quicker.
Rear Wheel Bearings gavinsky23 SV Talk, Tuning & Tweaking 0 28-05-08 01:09 PM
Which rear wheel bearings for a pointy? chunkytfg SV Talk, Tuning & Tweaking 3 07-03-08 12:43 AM
Rear wheel bearings mjf65 SV Talk, Tuning & Tweaking 3 25-10-07 01:25 PM
SV1000S rear wheel bearings Rocket SV Talk, Tuning & Tweaking 6 19-02-07 06:43 PM
Changing rear shock.... How easy/hard Iansv SV Talk, Tuning & Tweaking 32 29-05-06 07:15 PM
