Old 19-11-11, 03:32 PM   #1
McK
Default Non starter, what to do?
Working on my SV as it just wont start anymore. Thought it was the cold and the battery and last weekend took that out and charged it but alas that was not the fix.
Just back in today from delving a bit further and looking at filters and spark plugs. Plugs look a slightly darker brown than the pic here : http://forums.sv650.org/showthread.php?t=171636
Also the gap looks larger than the stated 0.8mm in haynes manual (havent got feeler gauges to check accurately). Plugs were sparking when placed against the engine - bright orange spark which seemed ok and regular. Spark plugs are iridium version and have probably done about 6k
Filter looks pretty black and furry. It is a K&N one so not sure if I can clean/repair - got no compressed air to blow through it.
So my next steps to get the bike back on the road seem to be buy some feeler gauges and replace filter. Is there anything else I should be checking also?
. Bike was serviced by Spannerman Feb 2010 and also looked at this summer for a replacement chain. Only other thing that I have noticed is a gradual drop in idling speed over several months.
Any advice / suggestions appreciated. If I cant fix it myself, any suggestions for a good mechanic around N London?
Doug
edit : Ive been mainly using it for short commuting runs through London, with the occasional blast into the country when weather/time permits.
Old 19-11-11, 03:48 PM   #2
Default Re: Maintenance help
You have PM.
Starter Relay, Starter Relay connector, Rear cush drive rubbers. yorkie_chris Stuff Wanted 4 08-07-11 09:32 PM
NC-35 non starter 7755matt Bikes - Talk & Issues 1 29-08-09 10:40 PM
Non Starter slloyd SV Talk, Tuning & Tweaking 3 01-03-09 03:11 PM
non starter evertheoptimist SV Talk, Tuning & Tweaking 9 09-05-08 06:19 AM
Non starter - help sticky-dizzle SV Talk, Tuning & Tweaking 11 12-04-07 02:38 AM
