Old 24-12-11, 12:41 PM   #1
Daveo2010
Default SV won't start after lowside
Hi all,
Fixing my bike up after a low speed drop, no sign of the starter turning over - should I suspect the gear position switch even though the neutral light works? Anything else might have broken? Is there a clutch lever position sensor?
Also if anyone has the following for sale (1999 curvy yellow S) please pm me: clutch lever, gear lever, front left panel, front left indicator glass.
(excuse brevity, I'm on my phone)
ta, Dave
Old 24-12-11, 01:08 PM   #2
mister c
mister c's Avatar
Default Re: SV won't start after lowside
Could try the clutch, or side stand switch
Old 24-12-11, 01:12 PM   #3
DJ123
DJ123's Avatar
have you checked the fuses?
BMW F800ST
Old 24-12-11, 01:14 PM   #4
TamSV
TamSV's Avatar
The clutch switch is a two prong connector located under the clutch perch. That would be my first thing to check.
Old 24-12-11, 01:32 PM   #5
Daveo2010
Near the lever? The clutch lever did take a proper battering.
Old 24-12-11, 01:55 PM   #6
BBadger
under the lever is a little "box" has the switch in it.
also do curves have a tip over switch ??
Old 24-12-11, 02:52 PM   #7
TamSV
TamSV's Avatar
No tip over switch on the curvy
Old 24-12-11, 06:09 PM   #8
vjones777
If the switch on the clutch is knackered, you can pull the connector off it, then stuff a paper clip (or other wire) across the connector. IIRC, you only need that to operate the starter - once its running you can pull the paper clip out.
That'll work until you can get the switch fixed.
Old 02-01-12, 07:53 PM   #9
Daveo2010
Confirmed it's the clutch switch. Just need to get the bits then!
Old 02-01-12, 10:28 PM   #10
Good stuff
FYI vjones is correct that you only need clutch switch for starter, not for it to run. And also if neutral light is working then that sends signal to the cut-out relay to allow it to run if stand is down.
Crash.NET - Stoner finds corner speed, suffers lowside. NewsBot News 0 12-06-09 06:20 PM
motosliders lowside test... erik Hardware 37 24-12-08 08:23 AM
Clocks start spinning and bike wont start?! lockery SV Talk, Tuning & Tweaking 4 13-04-06 07:32 AM
sad day!! bike lowside on diesel daddy_sperm SV Talk, Tuning & Tweaking 39 24-04-05 08:39 PM
winters here and a lowside as a result huge SV Talk, Tuning & Tweaking 5 03-12-04 10:24 PM
