Old 04-01-12, 07:26 PM   #1
Fifteen15
Default Draining battery with heated grips
I fitted some heated grips to the SV a few weeks ago but now everytime I leave my bike running and heated grips on I always think the battery will run flat. The grips use up to 4 amps, so how long would it take to drain an SV battery?
Thanks
Edit:
How long would they take to drain the battery if just the ignition was on?
Old 04-01-12, 07:43 PM   #2
SV Mad
Default Re: Draining battery with heated grips
If you're riding the battery is charging. Regardless of the grips being on the battery should be fine surely?
Old 04-01-12, 07:57 PM   #3
SVMAT
just dont leave them on with engine off. bumping the sv for the first time is a right kunt so i got em wired into ignition with relay. As for drain on battery it depends on how good nick your battery is in and how well its being charged. I always made sure i turned the heated grips off a couple mins before end of ride. HTH
Draining battery. hhh1234 SV Talk, Tuning & Tweaking 10 17-10-10 06:31 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
Constant Draining Battery decca1o Bikes - Talk & Issues 3 13-03-09 10:22 AM
Battery draining - Help PaulyMac SV Talk, Tuning & Tweaking 19 01-06-07 09:30 AM
Heated Grips - Killing the battery? seedy100 SV Talk, Tuning & Tweaking 5 20-02-06 12:44 AM
